System.NotSupportedException: Specified method is not supported
05 Oct 2025 13:45 #14393 by support
If you can run the Release configuration from inside the Visual Studio, but get this problem when running from a different location, then you are most likely not running the same thing. You must be using the very same assemblies (files) that Visual Studio has put into the build output.
05 Oct 2025 13:19 #14392 by micham
Hi
It happens when running it outside Visual Studio.
05 Oct 2025 08:50 #14391 by support
Please clarify whether the problem "running the Release versions" comes
a) from running it from the Visual Studio itself or by running the executable from the folder where the Visual Studio has just built it, or
b) running it from the some derived location, such as when you have built your product installer and then run the installed product.
03 Oct 2025 13:54 #14389 by support
Sent the license key by email. Will reply to your later post separately.
02 Oct 2025 18:17 #14387 by micham
When I run the project in DEBUG mode, I can browse OPC DA (or UA) items, but when I run the Release version, I get an exception. See below.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.TypeInitializationException: The type initializer for 'OpcLabs.EasyOpc.UA.EasyUAClientCore' threw an exception. ---> System.IO.FileLoadException: Could not load file or assembly 'System.Memory, Version=4.0.1.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
   at Microsoft.Extensions.Primitives.StringSegment.Equals(String text, StringComparison comparisonType)
   at Microsoft.Extensions.FileProviders.Physical.Internal.PathUtils.PathNavigatesAboveRoot(String path)
   at Microsoft.Extensions.FileProviders.Physical.PhysicalFilesWatcher.CreateFileChangeToken(String filter)
   at Microsoft.Extensions.FileProviders.PhysicalFileProvider.Watch(String filter)
   at Microsoft.Extensions.Configuration.FileConfigurationProvider.<.ctor>b__1_0()
   at Microsoft.Extensions.Primitives.ChangeToken.ChangeTokenRegistration`1..ctor(Func`1 changeTokenProducer, Action`1 changeTokenConsumer, TState state)
   at Microsoft.Extensions.Primitives.ChangeToken.OnChange(Func`1 changeTokenProducer, Action changeTokenConsumer)
   at Microsoft.Extensions.Configuration.FileConfigurationProvider..ctor(FileConfigurationSource source)
   at Microsoft.Extensions.Configuration.Json.JsonConfigurationSource.Build(IConfigurationBuilder builder)
   at Microsoft.Extensions.Configuration.ConfigurationBuilder.Build()
   at Microsoft.Extensions.Hosting.HostBuilder.InitializeAppConfiguration()
   at Microsoft.Extensions.Hosting.HostBuilder.Build()
   at OpcLabs.BaseLib.Extensions.Hosting.StaticHost.CreateHost()
   at System.Lazy`1.CreateValue()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Lazy`1.get_Value()
   at OpcLabs.BaseLib.Extensions.Hosting.StaticHost.GetConfiguration()
   at OpcLabs.EasyOpc.UA.EasyUAClientCore..cctor()
   at OpcLabs.EasyOpc.UA.EasyUAClientCore..ctor()
   at OpcLabs.EasyOpc.UA.EasyUAClient..ctor()
   at UCMECFG.OPC_UA.GlobalTagBrowseUA(String MyServerName)
   at UCMECFG.Module1.GlobalTagBrowse(String MyServer)
   at UCMECFG.Design1alert.Command4_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9310.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
UCMECFG
    Assembly Version: 2025.117.0.0
    Win32 Version: 2025.117.0.0
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/UCMECFG.EXE
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    Win32 Version: 4.8.9316.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.9251.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Win32 Version: 4.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
    Win32 Version: 4.8.9214.0 built by: NET481REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.ServiceProcess
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Xceed.Zip.v6.3
    Assembly Version: 6.3.17281.13580
    Win32 Version: 6.3.17281.13580
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Xceed.Zip.v6.3.DLL
ChilkatDotNet47
    Assembly Version: 9.5.0.97
    Win32 Version: 9.5.0.97
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/ChilkatDotNet47.DLL
KellermanSoftware.NET-Encryption-Library
    Assembly Version: 2.18.0.0
    Win32 Version: 2.18.0.0
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/KellermanSoftware.NET-Encryption-Library.DLL
Xceed.Compression.v6.3
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Xceed.Compression.v6.3.DLL
Xceed.FileSystem.v6.3
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Xceed.FileSystem.v6.3.DLL
OpcLabs.EasyOpcUAComponents
    Assembly Version: 5.82.395.1
    Win32 Version: 5.82.395.1
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcUAComponents.DLL
OpcLabs.EasyOpcUA
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcUA.DLL
OpcLabs.BaseLib
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.BaseLib.DLL
OpcLabs.EasyOpcForms
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.EasyOpcForms.DLL
OpcLabs.BaseLibForms
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/OpcLabs.BaseLibForms.DLL
System.Xml.Linq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
JetBrains.Annotations
    Assembly Version: 4242.42.42.42
    Win32 Version: 2024.3.0
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/JetBrains.Annotations.DLL
Microsoft.Extensions.DependencyInjection.Abstractions
    Assembly Version: 9.0.0.3
    Win32 Version: 9.0.325.11113
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
Microsoft.Extensions.Configuration.Abstractions
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.Abstractions.DLL
Opc.Ua.Core
    Assembly Version: 1.5.375.0
    Win32 Version: 1.5.375.457
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Opc.Ua.Core.DLL
Opc.Ua.Client
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Opc.Ua.Client.DLL
Microsoft.Extensions.FileProviders.Abstractions
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.FileProviders.Abstractions.DLL
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Primitives.DLL
Opc.Ua.Configuration
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Opc.Ua.Configuration.DLL
System.Net.Http
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
System.ComponentModel.DataAnnotations
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
System.Runtime.Serialization
    Win32 Version: 4.8.9241.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.ServiceModel
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.IdentityModel
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Microsoft.Extensions.Logging.Abstractions
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Logging.Abstractions.DLL
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.FileProviders.Physical.DLL
Microsoft.Extensions.Caching.Abstractions
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Caching.Abstractions.DLL
BoxedAppSDK.Managed
    Assembly Version: 2020.5.0.0
    Win32 Version: 2020.5.0.0
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/BoxedAppSDK.Managed.DLL
System.Design
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Xaml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Microsoft.Extensions.Hosting.Abstractions
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Hosting.Abstractions.DLL
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Hosting.DLL
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.DependencyInjection.DLL
System.Diagnostics.DiagnosticSource
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/System.Diagnostics.DiagnosticSource.DLL
System.ValueTuple
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ValueTuple/v4.0_4.0.0.0__cc7b13ffcd2ddd51/System.ValueTuple.dll
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.DLL
Microsoft.Extensions.Configuration.EnvironmentVariables
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.EnvironmentVariables.DLL
Microsoft.Extensions.Configuration.CommandLine
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.CommandLine.DLL
Microsoft.Extensions.Configuration.FileExtensions
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.FileExtensions.DLL
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.Json.DLL
Microsoft.Extensions.Configuration.UserSecrets
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.UserSecrets.DLL
Microsoft.Extensions.Configuration.Binder
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.Configuration.Binder.DLL
Microsoft.Extensions.FileSystemGlobbing
    CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/UCME-OPC/BIN/Microsoft.Extensions.FileSystemGlobbing.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
    02 Oct 2025 18:03 #14386 by micham
    Thank you. This sis now resolved.
    Can you please send me the license for this version?
    Michael Meirovitz
    Control See
    02 Oct 2025 07:59 - 02 Oct 2025 07:59 #14383 by support
    parameters have been added to the UIAdministerApplication method since the version you used before. There are are now two Boolean parameters at the end:
    opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...2~UIAdministerApplication.html
    The suggestion is to use True for both of them.
    Last edit: 02 Oct 2025 07:59 by support.
    01 Oct 2025 17:09 #14382 by micham
    After installing the new Nuget version and compiling the project, I get the following error:
    Error    BC30455    Argument not specified for parameter 'allowChangePrivateKeyPassword' of 'Public Shared Overloads Sub UIAdministerApplication(application As IEasyUAClientServerApplication, owner As IWin32Window, clientSelector As EasyUAClientSelector, allowPullCertificateManagement As Boolean, allowChangePrivateKeyPassword As Boolean)'.    UCMECFG    D:\MyBin\Proj-VS2017\UCME-OPC\Version 2025.0\UCME_CFG_NET(2,54)\UCMECFG\UCMECFG\Settings1.vb    1    Build    Active
    Any idea why?
    01 Oct 2025 16:31 #14381 by micham
    We shall try this new Nuget version.
    Our current version is using Nuget Package 5.80.192. The customer has removed this version and installed an older version that was built with Quick OPC version 2022.1.
    Using this older version he could browse DeltaV items with no problems.
    30 Sep 2025 08:29 #14380 by support
    can you please rebuild your product with updated QuickOPC (5.82.395, now on nuget.org and our Downloads page), and ask the customer to repeat the test and send over the full error message as before?
    The update is not meant to fix the problem, but it adds diagnostic information into the error message.
    Time to create page: 0.274 seconds
