Error "An OPC-UA operation failure with error code -2147483648 ..." in VM
03 Mar 2022 07:05 #10688 by support
I am sorry, but you still do not seem to be providing me with the right information. There seems to be some confusion about the nested exceptions.
Assuming that you have a try/catch block around the "read", and it catches "ex", then what I have asked for mainly is "ex.InnerException.Message".
In order to avoid further confusion, I suggest that you log and send me "ex.GetDescendLines()", where GetDescendLines() is an extension method in OpcLabs.BaseLib.Extensions.Internal namespace.
02 Mar 2022 11:29 #10685 by v.parma
Sorry but I understand, from "ex.InnerException.InnerException.Message" I receive this message:
An OPC-UA operation failure with error code -2147483648 (0x80000000) occurred, originating from 'System'. The inner OPC-UA service exception with service result 'Bad' contains details about the problem.The operation completed successfully.
My complete log is:
Title: ns=3;s=DB1001 StatusTable_Alarms_Alm GEN.12 - Main Panel High Temperature (4S3)
Message: An OPC-UA operation failure with error code -2147483648 (0x80000000) occurred, originating from 'System'. The inner OPC-UA service exception with service result 'Bad' contains details about the problem.The operation completed successfully
StackTrace: at OpcLabs.EasyOpc.UA.EasyUAClient.CheckSuccess(OperationResult operationResult)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.ReadValue(IEasyUAClient client, UAReadArguments readArguments)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.ReadValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor)
at OPC2SQL.frMain.PollingStatus()
Date/Time: 3/1/2022 3:42:34 PM
02 Mar 2022 09:36 #10684 by support
This is not what I have asked for.
I need you to provide the contents of the .InnerException property (mainly, its .Message) of the exception object you received.
regards
02 Mar 2022 08:31 #10682 by v.parma
From Windows Events Logs:
Faulting application name: tcpsvcs.exe, version: 10.0.19041.1, time stamp: 0x84e4661d
Faulting module name: ntdll.dll, version: 10.0.19041.964, time stamp: 0xb7db0838
Exception code: 0xc0000005
Fault offset: 0x00044544
Faulting process id: 0x1e0c
Faulting application start time: 0x01d82e0ed34f6c73
Faulting application path: C:\WINDOWS\SysWOW64\tcpsvcs.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: 987cc716-82df-4f04-a790-4ba76e660b4e
Faulting package full name:
Faulting package-relative application ID:
02 Mar 2022 07:30 #10681 by support
I need the inner exception, for troubleshooting.
02 Mar 2022 06:52 #10680 by v.parma
I have a my program with QuickOPC that working fine from one year on one Win10 PC, my customer ask my to move the program on a new Win10 Virtual Machine and on reading function I recive this error:
With OPC Expert Tool I can connect and read tag on OPC Server from this machine.
Anyone can help me?
