Error "An OPC-UA operation failure with error code -2147483648 ..." in VM
07 Mar 2022 10:29 #10705 by support
In addition, there appears to be some problem with the certificate that has already been generated - I suggest you clear all certificates related to your app from the stores.
07 Mar 2022 10:26 #10704 by support
The relevant message in the log is:
Exception: {System.UnauthorizedAccessException} Access to the path 'C:\ProgramData\OPC Foundation\CertificateStores\RejectedCertificates\private\OPC2SQL [FC6D42C5C14333F373945E42AD47014723164AEB].pfx' is denied.
So, you need to make sure that permissions exist (for the user that is running the app) to access the listed path.
07 Mar 2022 10:17 #10703 by v.parma
File Name: 20220307_2...3-07.txt
File Size:584 KB
07 Mar 2022 10:13 #10702 by v.parma
ok, I try to use recent version 2021.3.
See attached log.
06 Mar 2022 11:05 #10701 by support
unfortunately, since you are using version 5.54, and there were changes in newer versions in this area, plus an improved diagnostics, I cannot help you further.
Recommended action is to rebuild and test with current version, and if that works, version upgrade. If it does not work, it should at least give better diagnostics.
04 Mar 2022 16:54 #10698 by v.parma
I tryed with and without admin privilege, but the error is the same. I tryed also to move the folder with exe file and dlls from C:\... to Desktop, but doesn't communicate.
The log is the same with and without admin privilege.
I tryed also with EasyOpcUADemo of OPC Labs and this program on this VM working fine.
04 Mar 2022 16:26 #10695 by support
thank you.
Have you tried the first suggestion (running with elevated privileges), and what were the results. Or, is the log file actually from that run?
04 Mar 2022 15:56 #10694 by v.parma
04 Mar 2022 09:30 #10693 by support
thank you, this is very good, that's what I needed - at least for start.
The error tells us that there is some problem creating (auto-generating) the OPC UA application instance certificate for the client (your application). This happens before an OPC UA connection is even established.
1) Try to run the application with elevated privileges ("Run as Administrator") once.
2) if that does not help: Please add an event handler to the static EasyUAClient.LogEntry event, and capture all log messages generated during the (failed) start of your application.
03 Mar 2022 14:28 #10689 by v.parma
This?
Message: An OPC-UA operation failure with error code -2147483648 (0x80000000) occurred, originating from 'System'. The inner OPC-UA service exception with service result 'Bad' contains details about the problem.(1) {OpcLabs.EasyOpc.UA.OperationModel.UAException} OpcLabs.EasyOpcUA(CheckSuccess) -> An OPC-UA operation failure with error code -2147483648 (0x80000000) occurred, originating from 'System'. The inner OPC-UA service exception with service result 'Bad' contains details about the problem.
(2) {OpcLabs.EasyOpc.UA.UAServiceException} -> OPC-UA service result - Could not create a certificate via a proxy: The operation completed successfully = Bad. ---- SERVICE RESULT ---- Status Code: {Bad} = 0x80000000 (2147483648) + The SDK action called was "ApplicationInstance.CheckApplicationInstanceCertificate". + Following (4) events were gathered during the action on activity ID [3], in the order of first occurrence: SDK trace: Checking application instance certificate. SDK trace: Creating application instance certificate. KeySize=0, Lifetime=600 SDK trace: Deleting application instance certificate. Exception: {System.ComponentModel.Win32Exception} The operation completed successfully + The error occurred while creating or checking the (client) application instance certificate. Check event log entries for errors and warnings. + The certificate generator path was "C:\OPC2SQL_FPS1171\Opc.Ua.CertificateGenerator.exe". + This is an engine-level error. + The client method called was 'ReadMultiple'.
(3) {System.ComponentModel.Win32Exception} System(StartWithCreateProcess) -> The operation completed successfully
StackTrace: at OpcLabs.EasyOpc.UA.EasyUAClient.CheckSuccess(OperationResult operationResult)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.ReadValue(IEasyUAClient client, UAReadArguments readArguments)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.ReadValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor)
at OPC2SQL.frMain.PollingStatus()
Date/Time: 3/3/2022 11:20:46 AM
Time to create page: 0.074 seconds
