Error While Connecting to the Server
06 May 2024 13:00 - 06 May 2024 13:15 #12760 by Jannie@Moore
Hi there, I get this error 'An item with the same key has already been added. Key: Underflow'
on this line categoryElements = client.QueryEventCategories("", "Matrikon.OPC.GDA.1");
i have this server Matrikon.OPC.GDA.1 running and i have few Alarm Events configured.
When running the following code
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Net;
using System.Reflection.Metadata;
using OpcLabs.EasyOpc.AlarmsAndEvents;
using OpcLabs.EasyOpc.AlarmsAndEvents.AddressSpace;
using OpcLabs.EasyOpc.AlarmsAndEvents.OperationModel;
using OpcLabs.EasyOpc.OperationModel;
namespace OPCAETest
    internal class Program
            var client = new EasyAEClient();
            AECategoryElementCollection categoryElements;
            try
            catch (Exception Exception)
                Console.WriteLine("*** Failure: {0}", Exception.InnerException.Message);
                return;
            //catch (OpcException opcException)
            //    Console.WriteLine("*** Failure: {0}", opcException.GetBaseException().Message);
            //    return;
            foreach (AECategoryElement categoryElement in categoryElements)
                Debug.Assert(categoryElement != null);
                Console.WriteLine("Category {0}:", categoryElement);
                foreach (AEAttributeElement attributeElement in categoryElement.AttributeElements)
                    Debug.Assert(attributeElement != null);
                    Console.WriteLine("    Information about attribute {0}:", attributeElement);
                    Console.WriteLine("        .AttributeId: {0}", attributeElement.AttributeId);
                    Console.WriteLine("        .Description: {0}", attributeElement.Description);
                    Console.WriteLine("        .DataType: {0}", attributeElement.DataType);
            var eventHandler = new EasyAENotificationEventHandler(aeClient_Notification);
            client.Notification += eventHandler;
            // Keep the application running
            Console.WriteLine("Press any key to exit...");
            Console.ReadKey();
        // Notification event handler
        static void aeClient_Notification(object sender, EasyAENotificationEventArgs e)
            if (!e.Succeeded)
                Console.WriteLine("*** Failure: {0}", e.ErrorMessageBrief);
                return;
            if (!e.Refresh && (!(e.EventData is null)))
                // Display all received event attribute IDs and their corresponding values
                Console.WriteLine("Event attribute count: {0}", e.EventData.AttributeValues.Count);
                foreach (KeyValuePair<long, object> pair in e.EventData.AttributeValues)
                    Console.WriteLine("    {0}: {1}", pair.Key, pair.Value);
Last edit: 06 May 2024 13:15 by support.
Time to create page: 0.045 seconds
