Error While Connecting to the Server
I was not able to reproduce and troubleshoot the issue.
There are problems on both sides: The server returns the condition with the same name multiple times, which makes no sense. And, the client (QuickOPC) implementation cannot cope with it, and crashes.
We have made a fix on the client side. In case of name collisions like this, only one of the elements will be returned, and there will be no crash.
The fix is in version 5.80.192 or later, now available on www.nuget.org, and from our Downloads page.
Thank you for reporting this issue!
- Jannie@Moore
- Topic Author
- Offline
- Elite Member
- Thank you received: 0
I will re-test by running the application more times. I was not doing it before.
Also, which .NET runtime are you using? Is it .NET Framework (e.g. 4.6.x or 4.7.x or 4.8.x), or is it .NET Core, or .NET 5/6/7 ?
- Jannie@Moore
- Topic Author
- Offline
- Elite Member
Yes problem appear to be on the GDA server. but not show how to fix. If i run my demo application first time is able to work properly and fetch the events.
if i stop the applican and try to run again is complaining.
'An item with the same key has already been added. Key: Critical' somewhere is duplicating i checked my data doesnt have duplicates. maybe is cached by the server.
- Jannie@Moore
- Topic Author
- Offline
- Elite Member
QuickOPC version 5.61.343, this is the max version we can use based on our License. but i tried last version on trial i get same error.
It looks like you are using the sample configuration that goes with the server, right?
I tried it, but I could not reproduce the problem.
Which QuickOPC version are you using please?
And, which version of the MatrikonOPC GDA server?
- Jannie@Moore
- Topic Author
- Offline
- Elite Member
<Root Version="4.0">
<Node>
<Address>
<L-ink Value="Marshal" />
<L-ink Value="Matrikon_OPC_GDA_1" />
</Address>
<PersistentData>
<X-MLConfig>
<Matrikon.OPC.GDA>
<CGDARootDevLink name="" description="GDA Root">
<CGDAServerDevLink name="AlarmEventConnection" description="AlarmEventConnection" GDAProgID="Matrikon.GDA.ODBC" GDADescription="Matrikon GDA for ODBC(SQL Server)" GDAInitXML="<GDAInit ReadOnly="1" TimeOut="15" />" GDAConnectXML="<GDAConnect DSN="GDA ODBC" User="DignosTM" Password="^01`53e2fbc8548e564900f9f5cc3979074ed313cbe8cd4d096792cd3ab67641" />" QualityMap="[GOOD],[0],[BAD],[1],[UNCERTAIN],[2]" UseClampedTimestamps="0" ServerGDAChoice="1" PostgreInserts="0" MaxCustomQueryResult="10000" MaxHDAInsertQueryLimit="10000" UseDST="0">
<CGDAObjectDevLink name="Data Mapping" description="" ObjectType="Table" AETableName="ConditionalAlarm_TestTable" AEScanInterval="20000" AETagMap="[ID],[ID],[Latest],[],[Area],[Area],[Source],[Source],[CategoryID],[CategoryID],[Category],[CategoryName],[Timestamp],[TimeStamp],[Message],[Message],[Severity],[Severity],[Condition],[Condition],[SubCondition],[Sub-Condition],[Quality],[Quality],[Enabled],[Enabled],[Active],[Active],[Acknowledged],[Acknowledge],[AckTime],[Ack_Timestamp],[AckComment],[Ack_Comment],[ActorID],[Ack_Actor]" AERootAreaName="" />
</CGDAServerDevLink>
<CGDAServerDevLink name="Database Connection" description="" GDAProgID="Matrikon.GDA.ODBC" GDADescription="Matrikon GDA for ODBC(SQL Server)" GDAInitXML="<GDAInit ReadOnly="0" TimeOut="5" />" GDAConnectXML="<GDAConnect DSN="SQL Server" User="DignosTM" Password="^01`34875e6e2af0240ba4bfda9d124de0651bed781e34448c42e09ccb4754aa" />" QualityMap="[GOOD],[0],[BAD],[1],[UNCERTAIN],[2]" UseClampedTimestamps="0" ServerGDAChoice="1" PostgreInserts="0" MaxCustomQueryResult="10000" MaxHDAInsertQueryLimit="10000" UseDST="0" />
<CServerStatusDevLink name="Server Status" description="Server Status Devlink" statusCheckPeriod="5000" oneConnect="-1" directList="AlarmEventConnection,AlarmEventConnection.Data Mapping,Database Connection,TestDatabase,TestDatabase.Query_events,TestDatabase.Query_history,TestDatabase.Query_integer,TestDatabase.Query_text,TestDatabase.Table_events,TestDatabase.Table_history,TestDatabase.Table_int,TestDatabase.Table_namedhistory,TestDatabase.Table_text,TestDatabase._Multi_Query,TestDatabase._Multi_Table" parentList="" />
<CGDAServerDevLink name="TestDatabase" description="" GDAProgID="Matrikon.GDA.ODBC" GDADescription="Matrikon GDA for ODBC(MS Access)" GDAInitXML="<GDAInit ReadOnly="0" TimeOut="5" />" GDAConnectXML="<GDAConnect DSN="TestDatabase" User="" Password="" />" QualityMap="[GOOD],[0],[BAD],[1],[UNCERTAIN],[2]" UseClampedTimestamps="0" ServerGDAChoice="0" PostgreInserts="0" MaxCustomQueryResult="20000" MaxHDAInsertQueryLimit="20000" UseDST="0">
<CGDAObjectDevLink name="Query_events" description="" ObjectType="Query" AERefreshQuery="select * from EVENTS" AEScanQuery="select * from EVENTS where ID > {RowID}" AEAckUpdateQuery="update EVENTS set Ack = 1, AckTime = '{AckTimestamp}', AckComment = '{AckComment}', AckActor = '{AckActor}' where ID = {RowID}" AEScanInterval="5000" AETagMap="[ID],[ID],[Area],[Area],[Source],[Source],[CategoryID],[CategoryID],[Category],[Category],[Timestamp],[EventTime],[Message],[Message],[Severity],[Severity],[Condition],[Condition],[SubCondition],[Subcondition],[Quality],[Quality],[Enabled],[Enabled],[Active],[Active],[Acknowledged],[Ack],[AckTime],[AckTime],[AckComment],[AckActor],[ActorID],[AckComment],[Custom:X],[Custom1],[Custom:Y],[Custom2]" AERootAreaName="" />
<CGDAObjectDevLink name="Query_history" description="" ObjectType="Query" DAQuery="" DAQueryTagMap="" MultiColTagname="false" TagnameSeperator="_" DATagname_1="" DATagname_2="" DATagname_3="" HDATagname_1="" HDATagname_2="" HDATagname_3="" HDAQuery="select * from HISTORICAL_TABLE_NAMED" HDAQueryTagMap="[TagName],[TAG_NAME],[],[Value],[VALUE],[],[Timestamp],[TIME],[],[Quality],[QUALITY],[]" />
<CGDAObjectDevLink name="Query_integer" description="" ObjectType="Query" DAQuery="select * from INTEGER_TABLE" DAQueryTagMap="[TagName],[TAG_NAME],[],[Value],[TAG_VALUE],[],[Timestamp],[TAG_TIMESTAMP],[],[Quality],[TAG_QUALITY],[]" MultiColTagname="false" TagnameSeperator="_" DATagname_1="" DATagname_2="" DATagname_3="" HDATagname_1="" HDATagname_2="" HDATagname_3="" HDAQuery="" HDAQueryTagMap="" />
<CGDAObjectDevLink name="Query_text" description="" ObjectType="Query" DAQuery="select * from TEXT_VALUES" DAQueryTagMap="[TagName],[TAG_NAME],[],[Value],[TAG_VALUE],[],[Timestamp],[TAG_TIMESTAMP],[],[Quality],[TAG_QUALTIY],[]" MultiColTagname="false" TagnameSeperator="_" DATagname_1="" DATagname_2="" DATagname_3="" HDATagname_1="" HDATagname_2="" HDATagname_3="" HDAQuery="" HDAQueryTagMap="" />
<CGDAObjectDevLink name="Table_events" description="" ObjectType="Table" AETableName="EVENTS" AEScanInterval="5000" AETagMap="[ID],[ID],[Latest],[],[Area],[Area],[Source],[Source],[CategoryID],[CategoryID],[Category],[Category],[Timestamp],[EventTime],[Message],[Message],[Severity],[Severity],[Custom:X],[Custom1],[Custom:Y],[Custom2]" AERootAreaName="SimpleEvents" />
<CGDAObjectDevLink name="Table_history" description="" ObjectType="Table" DATableName="" DATagnameColumn="" DAValueColumn="" DAQualityColumn="" DATimestampColumn="" DABatchColumn="" DAInsertTimeColumn="" MultiColTagname="false" TagnameSeperator="_" DATagname_1="" DATagname_2="" DATagname_3="" HDATableName="HISTORICAL_TABLE" HDATagnameColumn="*Use Table Name*" HDAValueColumn="VALUE" HDAQualityColumn="QUALITY" HDATimestampColumn="TIME" HDABatchColumn="" HDATagname_1="" HDATagname_2="" HDATagname_3="" BulkWriteEnabled="false" HDACheckBeforeInsert="true" HDAInsertTimeColumn="" />
<CGDAObjectDevLink name="Table_int" description="" ObjectType="Table" DATableName="INTEGER_TABLE" DATagnameColumn="TAG_NAME" DAValueColumn="TAG_VALUE" DAQualityColumn="TAG_QUALITY" DATimestampColumn="TAG_TIMESTAMP" DABatchColumn="" DAInsertTimeColumn="" MultiColTagname="false" TagnameSeperator="_" DATagname_1="" DATagname_2="" DATagname_3="" HDATableName="" HDATagnameColumn="" HDAValueColumn="" HDAQualityColumn="" HDATimestampColumn="" HDABatchColumn="" HDATagname_1="" HDATagname_2="" HDATagname_3="" BulkWriteEnabled="false" HDACheckBeforeInsert="true" HDAInsertTimeColumn="" />
<CGDAObjectDevLink name="Table_namedhistory" description="" ObjectType="Table" DATableName="" DATagnameColumn="" DAValueColumn="" DAQualityColumn="" DATimestampColumn="" DABatchColumn="" DAInsertTimeColumn="" MultiColTagname="false" TagnameSeperator="_" DATagname_1="" DATagname_2="" DATagname_3="" HDATableName="HISTORICAL_TABLE_NAMED" HDATagnameColumn="TAG_NAME" HDAValueColumn="VALUE" HDAQualityColumn="QUALITY" HDATimestampColumn="TIME" HDABatchColumn="" HDATagname_1="" HDATagname_2="" HDATagname_3="" BulkWriteEnabled="false" HDACheckBeforeInsert="true" HDAInsertTimeColumn="" />
<CGDAObjectDevLink name="Table_text" description="" ObjectType="Table" DATableName="TEXT_VALUES" DATagnameColumn="TAG_NAME" DAValueColumn="TAG_VALUE" DAQualityColumn="TAG_QUALTIY" DATimestampColumn="TAG_TIMESTAMP" DABatchColumn="" DAInsertTimeColumn="" MultiColTagname="false" TagnameSeperator="_" DATagname_1="" DATagname_2="" DATagname_3="" HDATableName="" HDATagnameColumn="" HDAValueColumn="" HDAQualityColumn="" HDATimestampColumn="" HDABatchColumn="" HDATagname_1="" HDATagname_2="" HDATagname_3="" BulkWriteEnabled="false" HDACheckBeforeInsert="true" HDAInsertTimeColumn="" />
<CGDAObjectDevLink name="_Multi_Query" description="DA Query Mapping example with multi col tagname enabled" ObjectType="Query" DAQuery="SELECT `TAG_NAME`, `TAG_DESC`, `TAG_AREA`, `TAG_STUFF`, `TAG_VALUE`, `TAG_TIMESTAMP`, `TAG_QUALITY`, `Index` FROM `INTEGER_TABLE_MULTI_HIST` WHERE `TAG_NAME` = 'VALVE_PRESSURE1'" DAQueryTagMap="[TagName],[TAG_NAME],[],[Value],[TAG_VALUE],[],[Timestamp],[TAG_TIMESTAMP],[],[Quality],[TAG_QUALITY],[]" MultiColTagname="true" TagnameSeperator="=" DATagname_1="TAG_DESC" DATagname_2="TAG_AREA" DATagname_3="TAG_STUFF" HDATagname_1="" HDATagname_2="" HDATagname_3="" HDAQuery="" HDAQueryTagMap="" />
<CGDAObjectDevLink name="_Multi_Table" description="DA Table Mapping example with multi col tagname enabled" ObjectType="Table" DATableName="INTEGER_TABLE_MULTI" DATagnameColumn="TAG_NAME" DAValueColumn="TAG_VALUE" DAQualityColumn="TAG_QUALITY" DATimestampColumn="TAG_TIMESTAMP" DABatchColumn="" DAInsertTimeColumn="" MultiColTagname="true" TagnameSeperator="¤" DATagname_1="TAG_DESC" DATagname_2="TAG_AREA" DATagname_3="TAG_STUFF" HDATableName="" HDATagnameColumn="" HDAValueColumn="" HDAQualityColumn="" HDATimestampColumn="" HDABatchColumn="" HDATagname_1="" HDATagname_2="" HDATagname_3="" BulkWriteEnabled="false" HDACheckBeforeInsert="true" HDAInsertTimeColumn="" />
</CGDARootDevLink>
</Matrikon.OPC.GDA>
</XMLConfig>
</PersistentData>
</Node>
</Root>
- Jannie@Moore
- Topic Author
- Offline
- Elite Member
I can see the created events in Matrikon OPC Explorer. problem only occurs when i try to read the data using OPC Labs API
can you post or send the configuration of the server?
It seems like some kind of misbehavior on the server side, but at the same time something we should be able to cope with better. So I would like to investigate "live", and then provide a fix, if possible.
