vb6 connection parameters
13 Sep 2021 09:16 #10202 by support
Replied by support on topic vb6 connection parameters
ValueResult is an object that, in case of success, holds the value that was read (in the .Value property), or, in case of failure, the information about the error (in the .Exception property, and some other properties).
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User's...perationModel.ValueResult.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User's...Model.ValueResult_members.html
I do not quite understand what you mean by "vb6 gives me an 'undefined object error'". When you run the program, does it stop and show you this error? If so, on which line? (can you provide a screenshot)? Or, are you intentionally, stepping through it in a debugger, and you get this at some place/in some moment? Please try to describe very clearly what is happening; thank you.
13 Sep 2021 09:03 #10201 by ulix86
Replied by ulix86 on topic vb6 connection parameters
thank you, the endpoint descriptor is the solution but I don't understand this code:
' Display results Dim i: For i = LBound(results) To UBound(results) Dim Result As ValueResult: Set Result = results(i) If Result.Succeeded Then OutputText = OutputText & "Value: " & Result.Value & vbCrLf Else OutputText = OutputText & "*** Failure: " & Result.ErrorMessageBrief & vbCrLf End If Next
what's ValueResult in the variable Result declaration? vb6 gives me an 'undefined object error'...
09 Aug 2021 07:25 #10099 by support
The simple "ReadValue" method cannot do that.
You need to use the ReadMultipleValues method instead, because it gets passed an "endpoint descriptor" which can in turn contains the user name and password. You can use ReadMultipleValues for reading just one value, too.
An example of using the ReadMultipleValues: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...0Read%20multiple%20values.html .
In the endpoint descriptor, the code to set the user name and password will look similar to this:
EndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "appadmin" EndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "demo"
06 Aug 2021 07:24 #10097 by ulix86
I have a problem with connecting to the OPCUA SERVER and VB6.
I installed QuickOPC 2019.2 for compatibility with windows7 so.
I found Vb6 code in Documentations and Helps for read a node value and display it
but I didn't find how to specified username and password and type of autentication.
This how I read the node:
' Read node value and display it
Me.Text1 = Client.ReadValue("opc.tcp://172.16.108.35:4840", "ns=2;i=4179")
but return a runtime error BadUserAccessDenied.
I think i should specify username and password and type of connection, right?
Is there documentations about this type of connection in vb6?
thank you (and sorry for my english ;) )
