vb6 connection parameters
15 Sep 2021 10:04 #10223 by support
Replied by support on topic vb6 connection parameters
the prompt can be suppressed using some settings, and we can discuss that, but that is definitely not the secure way of handling it. Because if you do that, your client would happily connect to any server, including a rogue server.
The right way is to make that specific server certificate trusted. This is usually done simply by finding the appropriate certificate file in the directory for rejected certificates, and moving or copying it over to the trusted certificates directory. Related information:
- kb.opclabs.com/Using_OpcCmd_Utility_for_OPC_UA_Administration
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Instance%20Certificate.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ic%20Certificate%20Stores.html
15 Sep 2021 09:38 #10222 by ulix86
Replied by ulix86 on topic vb6 connection parameters
Thank you.;)
I have another question to ask, please.
I would like to bypass the "certificate notification" when I start the connection to the OPC-UA server. (see attached below)
I tried to insert this line but unfortunatley doesn't work:
ReadArguments1.EndpointDescriptor.CertificateAcceptancePolicy.AcceptAnyCertificate = True
Dim ReadArguments1 As New UAReadArguments ReadArguments1.EndpointDescriptor.UrlString = "Server" ReadArguments1.EndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "user" ReadArguments1.EndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "password" ReadArguments1.EndpointDescriptor.CertificateAcceptancePolicy.AcceptAnyCertificate = True ReadArguments1.NodeDescriptor.NodeId.expandedText = "ns=2;s=Channel_1-ExecutionState"
Is the right way to do it?
13 Sep 2021 16:15 #10214 by support
OK I am glad that it works now.
Sometimes the problem is that a connection over an insecure endpoint is made, and that endpoint does not support user authentication. But it appears that your issue was different.
13 Sep 2021 15:49 #10213 by ulix86
Sorry, it works...the problem was the Permission Rules on the machine!
thank you for support.
13 Sep 2021 14:48 #10212 by ulix86
sorry, the connection is
- ip: 192.168.0.77
- Username: MEP_SPA
- Password: ***********
13 Sep 2021 14:46 #10211 by ulix86
I try to explain the problem, in my company there is a sawing machine (ip: 172.16.108.33)
with an OPC-UA server installed.
I can already read and write nodes value with UAExpert but I need to implement an automation script with VB6
to read/write data from/to the machine.
The connection login is:
- Username: admin
- Password: admin
See attachments below.
is the endpoint connection the right way to do it?
thank you
13 Sep 2021 11:05 #10206 by support
Can you post here a picture of endpoints offered by this server in UAExpert, and mark the one you are using?
13 Sep 2021 10:45 #10205 by ulix86
Thank you, it works! I missed the reference baselib!
but I have another question...
When I try to connect the server show me :
*** Failure: OPC-UA service result - Endpoint does not support the user identity type provided. = BadUserAccessDenied. [...]
Username and password are correct, with UAExpert Client it works fine.
I did something wrong with the code?
Dim ReadArguments1 As New UAReadArguments ReadArguments1.EndpointDescriptor.UrlString = "opc.tcp://172.16.108.33:4840" ReadArguments1.EndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "username" ReadArguments1.EndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "password" ReadArguments1.NodeDescriptor.NodeId.expandedText = "ns=2;i=4164" 'total cut time
thank you.
13 Sep 2021 09:44 #10203 by ulix86
I'll try to be more clearly.
When I try to run the program, does it stop and show me the "undefined object error" in
Dim Result As ValueResult
line.
probably because ValueResult object is not part of the project.
Is it a class module? I have to declare it?
I did'nt find nothing about ValueResult in the vb6 examples.
