Connecting to a PLC with anonymous users turned off
21 Nov 2025 09:53 #14475 by support
The OPC UA server decides whether it allows username/password authentication without a certificate. Most servers do not allow it, for security reasons (without the certificate, the username/password appear unencrypted on the wire and can be eavesdropped on).
From the error you are getting, it looks like that your server either does not all allow username/password authentication without a certificate, or it may allow it but is not currently configured is such a way. Consult the server vendor/documentation if this can be changed.
To resolve the error *with* the use of certificates, you need to go to the server side and make it trust the client certificate from your app (QuickOPC has created one for you).
20 Nov 2025 21:34 #14472 by Cwardltu
Is it possible to connect to a plc using a username and password with anonymous users turned off and not trusted cert configured. I am having issues doing so; initially i connect fine but if i were to reinitialize i start getting issues like the ones below:
I have also added a code snipit below.
x80860000: OPC UA service result - {BadSecureChannelClosed}. The secure channel has been closed. [...]
[Connection Event] Server is UNAVAILABLE - OPC UA service result - {BadSecureChannelClosed}. The secure channel has been closed.
+ The server may have rejected the connection because it does not trust the client (e.g. certificate problem); check the diagnostics on the server side, if possible.
+ The client method called (or event/callback invoked) was 'ServerConditionChanged'.
public void ConnectAsync(string serverURL, string userName = null, string password = null) {     if (string.IsNullOrWhiteSpace(serverURL))         throw new ArgumentNullException(nameof(serverURL));     if (_connected)         Disconnect();     if (_client == null)         _client = new EasyUAClient();     // Accept any certificate     EasyUAClientCore.SharedParameters.EngineParameters.CertificateAcceptancePolicy.AcceptAnyCertificate = true;     _serverUrl = serverURL;     Console.WriteLine("========================================");     Console.WriteLine($"[Connect] Server URL: {serverURL}");     // Simple endpoint creation - let client auto-select best available     Endpoint = new UAEndpointDescriptor(serverURL);     // Add username/password if provided     if (!string.IsNullOrWhiteSpace(userName) && !string.IsNullOrWhiteSpace(password))     {         Console.WriteLine($"[Connect] Username: {userName}");         Endpoint.UserIdentity.UserNameTokenInfo = new OpcLabs.BaseLib.IdentityModel.User.UserNameTokenInfo(userName, password);     }     else     {         Console.WriteLine("[Connect] Authentication: Anonymous");     }     // Try to connect by reading namespaces     _namespaces = new Dictionary<int, string>();     try     {         Console.WriteLine("[Connect] Connecting...");         var nsValues = _client.ReadValue(Endpoint, UAVariableIds.Server_NamespaceArray);         if (nsValues != null && nsValues is string[] namespaceValues)         {             int i = 0;             foreach (var nsValue in namespaceValues)             {                 _namespaces.Add(i++, nsValue);             }             Console.WriteLine($"[Connect] ✓ SUCCESS - {_namespaces.Count} namespaces");         }     }     catch (Exception ex)     {         Console.WriteLine("========================================");         Console.WriteLine("[Connect] ✗ FAILED");         Console.WriteLine($"[Connect] Exception: {ex.GetType().Name}");         Console.WriteLine($"[Connect] Message: {ex.Message}");         if (ex.InnerException != null)         {             Console.WriteLine($"[Connect] Inner: {ex.InnerException.GetType().Name}");             Console.WriteLine($"[Connect] Inner Message: {ex.InnerException.Message}");             if (ex.InnerException.InnerException != null)             {                 Console.WriteLine($"[Connect] Inner-Inner: {ex.InnerException.InnerException.Message}");             }         }         Console.WriteLine("========================================");         throw;     }     _connected = _namespaces.Count > 0;     if (_connected)     {         Console.WriteLine("========================================");     }     // SET UP CONNECTION MONITORING     _connectionMonitoring = _client.GetService<IEasyUAClientConnectionMonitoring>();     if (_connectionMonitoring != null)     {         _connectionMonitoring.ServerConditionChanged += onServerConditionChanged;         Console.WriteLine("Connection monitoring enabled");     }     else     {         Console.WriteLine("Warning: Connection monitoring service not available");     }     _connectionControl = _client.GetService<IEasyUAClientConnectionControl>();     if (_connectionControl == null)     {         Console.WriteLine("Warning: Connection control service not available");     } }
