Unable to connect with IGS OPC UA server
31 Jan 2023 06:24 #11499 by micham
I have modified the server's end-points. See below.
This is the endpoint I am using:
opc.tcp://mike2022:49310
    30 Jan 2023 17:04 #11497 by support
    I am glad that it works now. Can you share how you made it - what was wrong or needed to change?
    30 Jan 2023 16:17 #11496 by micham
    I was able to connect. Thank you.
    You may close this case.
    Thank you for your support!
    30 Jan 2023 15:15 #11495 by support
    thank you for the screenshots.
    The "Server Endpoints" tab is correct, I believe it should work with these settings.
    The "Trusted Clients" is not quite correct, your clients should appear there, either as Trusted, or at least Rejected initially. This is of course not the reason for the problem, but rather an effect of the problem (because the communication does not get that far for the server to "see" the client certificates), so nothing to be fixed right there. But it is helpful for me to know!
    I now need two additional pieces of information please:
    1. When you are trying to connect to the server using some of the applications written with QuickOPC , do you get any client-side popups asking you to confirm the server certificate?
    2. Please figure out the full version number (including build/revision - the 4 parts altogether) of QuickOPC you are building with.
    28 Jan 2023 07:10 #11493 by micham
    Hi, Sure. See below.
    IGS > OPC UA Configuration:
    27 Jan 2023 19:36 #11492 by support
    thanks, unfortunately there isn't much detail in this server log.
    Can you post here screenshots of the "Server Endpoints" and "Trusted Clients" tabs of the "OPC UA Configuration Manager" of the server?
    27 Jan 2023 17:24 #11489 by micham
    See the server diagnostics window when I try to connect. It says: "BadSecurityChecksFailed".
    27 Jan 2023 15:35 #11486 by support
    Regarding the security settings: I would reserve playing with them for later. But here is the info:
    - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...in%20Endpoint%20Selection.html
    - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...e.html#Server%20Endpoints.html
    - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...oint%20Selection%20Policy.html
    What do you mean by "I don't see anything on the server side..."?. Is there something like a server log, and are you saying that it is empty? Or you just do not know where it is or are you saying that the server does not have that?
    27 Jan 2023 15:16 #11484 by micham
    1. I don't see anything on the server side...
    2. Question: can the OPC client (Quick-OPC) programatically set the Security Policy and the Security Mode properties like in UA Expert?
    27 Jan 2023 15:08 #11483 by support
    There should be something in the server that would tell you why it is giving BadSecurityChecksFailed .
    Time to create page: 0.180 seconds
