Subscription/Unsubscription/Dispose with multiple clients
30 Dec 2022 15:08 #11393 by mpp
The tests are passing now, thank you.
30 Dec 2022 14:51 #11392 by support
your expectations, and your code, are correct. This is a QuickOPC bug. Thanks for reporting it!
It should be now fixed. Please download the current release (5.70.525.1 or later), rebuild your project with it, and re-test.
The following user(s) said Thank You: mpp
29 Dec 2022 16:50 - 29 Dec 2022 18:41 #11388 by mpp
Hi!
I'm using the latest nuget version 5.70.507.
I prepared this test to explain the issue I'm having with the EasyUAClients:
static readonly string _endpoint = "opc.tcp://<IP>:<PORT>";
static readonly string _variable = "ns=4;s=|var|<BOOLEAN_VARIABLE>";
[TestMethod]
public void TestSubscription_DisposeClient()
    EasyUAClient.SharedParameters.EngineParameters.CertificateAcceptancePolicy.TrustedEndpointUrlStrings.Clear();
    EasyUAClient.SharedParameters.EngineParameters.CertificateAcceptancePolicy.TrustedEndpointUrlStrings.Add(_endpoint);
    var client1 = MakeClient();
    var client1_suscriptionEventCounter = 0;
    client1.DataChangeNotification += (s, e) => client1_suscriptionEventCounter++;
    var client2 = MakeClient();
    var client2_suscriptionEventCounter = 0;
    client2.DataChangeNotification += (s, e) => client2_suscriptionEventCounter++;
    client1.WriteValue(_endpoint, _variable, true);
    client1.WriteValue(_endpoint, _variable, false);
    Thread.Sleep(2000);
    Assert.IsTrue(client1_suscriptionEventCounter > 0);
    Assert.IsTrue(client2_suscriptionEventCounter > 0);
    client1.UnsubscribeAllMonitoredItems();
    client1.Dispose();
    client2.WriteValue(_endpoint, _variable, true);
    client2.WriteValue(_endpoint, _variable, false);
    Thread.Sleep(500);
    Thread.Sleep(500);
    Thread.Sleep(500);
    Thread.Sleep(2000);
    Assert.AreEqual(0, client1_suscriptionEventCounter);
private EasyUAClient MakeClient()
    var toSubscribe =
        new EasyUAMonitoredItemArguments[]
            new EasyUAMonitoredItemArguments(new UAAttributeArguments(_endpoint, _variable))
    client.SubscribeMultipleMonitoredItems(toSubscribe);
    return client;
The test fails on the last Assert where I'm expecting the second client (the not disposed one) to maintain its subscription.
Is this the expected behavior or a bug?
I also tried the same test with a previous version that we were using 5.62.1032 and the test passes with that version.
With the new version I tried to set `true` to the `Isolated` property of the client and the test passes this way.
What are the drawbacks on using the clients in isolation?
Michele
Last edit: 29 Dec 2022 18:41 by mpp. Reason: More tests performed
