After installing our product, our main program fails to start.
27 Sep 2023 07:16 #12244 by micham
You may close this case. The problem was with the config file of our software. From a reason I don't understand the config file was different in the Debug and Release folders.
26 Sep 2023 19:57 #12241 by micham
After installing our product, our main program fails to start. See the information below from the Event Viewer.
1)
Faulting application name: EBOOPCClientCFG.exe, version: 1.0.108.0, time stamp: 0x6511d73a
Faulting module name: KERNELBASE.dll, version: 10.0.22621.2283, time stamp: 0x27eb36ec
Exception code: 0xe0434352
Fault offset: 0x001489f2
Faulting process id: 0x0x72BC
Faulting application start time: 0x0x1D9F0B2E14980E5
Faulting application path: C:\Program Files (x86)\Control-See\EBO-OPC Client\BIN\EBOOPCClientCFG.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 1d28c70a-6c27-4bae-ac7f-5fdc9243a8d2
Faulting package full name:
Faulting package-relative application ID:
- System
- Provider
[ Name] Application Error
[ Guid] {a0e9b465-b939-57d7-b27d-95d8e925ff57}
EventID 1000
Version 0
Level 2
Task 100
Opcode 0
Keywords 0x8000000000000000
- TimeCreated
[ SystemTime] 2023-09-26T19:51:48.5516903Z
EventRecordID 148733
Correlation
- Execution
[ ProcessID] 30900
[ ThreadID] 4656
Channel Application
Computer mike2022
- Security
[ UserID] S-1-5-21-1183210274-704692480-2757958250-1001
- EventData
AppName EBOOPCClientCFG.exe
AppVersion 1.0.108.0
AppTimeStamp 6511d73a
ModuleName KERNELBASE.dll
ModuleVersion 10.0.22621.2283
ModuleTimeStamp 27eb36ec
ExceptionCode e0434352
FaultingOffset 001489f2
ProcessId 0x72bc
ProcessCreationTime 0x1d9f0b2e14980e5
AppPath C:\Program Files (x86)\Control-See\EBO-OPC Client\BIN\EBOOPCClientCFG.exe
ModulePath C:\WINDOWS\System32\KERNELBASE.dll
IntegratorReportId 1d28c70a-6c27-4bae-ac7f-5fdc9243a8d2
PackageFullName
PackageRelativeAppId
2)
Application: EBOOPCClientCFG.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileLoadException
at System.MemoryExtensions.AsSpan(System.String, Int32, Int32)
at Microsoft.Extensions.FileProviders.Physical.Internal.PathUtils.PathNavigatesAboveRoot(System.String)
at Microsoft.Extensions.FileProviders.Physical.PhysicalFilesWatcher.CreateFileChangeToken(System.String)
at Microsoft.Extensions.FileProviders.PhysicalFileProvider.Watch(System.String)
at Microsoft.Extensions.Configuration.FileConfigurationProvider.<.ctor>b__1_0()
at Microsoft.Extensions.Primitives.ChangeToken+ChangeTokenRegistration`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]..ctor(System.Func`1<Microsoft.Extensions.Primitives.IChangeToken>, System.Action`1<System.__Canon>, System.__Canon)
at Microsoft.Extensions.Primitives.ChangeToken.OnChange(System.Func`1<Microsoft.Extensions.Primitives.IChangeToken>, System.Action)
at Microsoft.Extensions.Configuration.FileConfigurationProvider..ctor(Microsoft.Extensions.Configuration.FileConfigurationSource)
at Microsoft.Extensions.Configuration.Json.JsonConfigurationSource.Build(Microsoft.Extensions.Configuration.IConfigurationBuilder)
at Microsoft.Extensions.Configuration.ConfigurationBuilder.Build()
at Microsoft.Extensions.Hosting.HostBuilder.BuildAppConfiguration()
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at OpcLabs.BaseLib.Extensions.Hosting.StaticHost.CreateHost()
at System.Lazy`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].CreateValue()
at System.Lazy`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].LazyInitValue()
at System.Lazy`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].get_Value()
at OpcLabs.BaseLib.Extensions.Hosting.StaticHost.GetConfiguration()
at OpcLabs.EasyOpc.UA.EasyUAClient..cctor()
Exception Info: System.TypeInitializationException
at OpcLabs.EasyOpc.UA.EasyUAClient..ctor()
at EBO_Browse.Form1..ctor()
Exception Info: System.InvalidOperationException
at EBO_Browse.My.MyProject+MyForms.Create__Instance__[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.__Canon)
at EBO_Browse.My.MyApplication.OnCreateMainForm()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(System.String[])
at EBO_Browse.My.MyApplication.Main(System.String[])
Any idea what is the problem?
Time to create page: 0.071 seconds
