Could not load file or assembly...
29 Mar 2021 12:45 #9579 by support
First, please check that the assembly specified in the exception message is actually present on the disk, together with the other assemblies of your application. I understand that you *are* referencing it; but there are sometimes issues with Visual Studio not copying the assembly to the output folder, or similar problems.
If the assembly file is present where it should be: The next thing to consider is the reason mentioned in the exception message, i.e. missing C++ redistributable libraries. Normally QuickOPC uses a special technique so that no such prerequisite needs to be installed, but it may fail under special circumstances. (opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ml#Prerequisites%20Boxing.html )
The link to the proper version of the C++ redistributables (warning - there are many version of them!) is installed with the product, specific to the version you are using (question: which version are you using?). For the current version (2021.1) and some versions below, the link is support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads .
The following user(s) said Thank You: Ai2Infinity
29 Mar 2021 10:20 #9578 by Ai2Infinity
Good morning,
I have an issue with when writing to tags from an asp.net web page after deployment. It runs fine on my local machine in source code. For context, I have a .net application running on the deployed machine and it runs fine. It is just the ASP.Net Web Page that is the issue. I have installed the OPCLabs redistributable package on the remote machine.
I have attached screen shot of error and current reference list in ASP.Net project.
Thank you for your help.
Craig
