Compiler Warning when targeting net60 or netstandard21
26 Feb 2023 10:15 #11574 by support
yes, your are right. I have investigated this and it comes from our use of the Microsoft.Net.Http package (a leftover from earlier version). It needs to be replaced by the newer System.Net.Http.
I have checked the code thoroughly, and the only place a code from that package can be called is when you actually use HTTPS for OPC UA connection (very unlikely; everybody uses opc.tcp); and even then it might actually work.
So, this will be fixed in the next version. But not in the current version, unless it actually causes a real problem.
24 Feb 2023 08:45 #11571 by Hofinger
I am currently evaluating the OpcLabs.QuickOpc-nuget.
When I use version 5.70.1053 together with net6.0 or netstandard2.1, I get the following warnings upon nuget restore:
Warning	NU1701	Package 'Microsoft.Bcl 1.1.10' was restored using '.NETFramework,Version=v4.6.1, .NETFramework,Version=v4.6.2, .NETFramework,Version=v4.7, .NETFramework,Version=v4.7.1, .NETFramework,Version=v4.7.2, .NETFramework,Version=v4.8, .NETFramework,Version=v4.8.1' instead of the project target framework 'net6.0'. This package may not be fully compatible with your project.
Warning	NU1701	Package 'Microsoft.Net.Http 2.2.29' was restored using '.NETFramework,Version=v4.6.1, .NETFramework,Version=v4.6.2, .NETFramework,Version=v4.7, .NETFramework,Version=v4.7.1, .NETFramework,Version=v4.7.2, .NETFramework,Version=v4.8, .NETFramework,Version=v4.8.1' instead of the project target framework 'net6.0'. This package may not be fully compatible with your project.
These warnings do not show up, when using the previous version (5.63.246).
Time to create page: 0.075 seconds
