UAException -
07 Feb 2022 16:21 #10588 by support
Replied by support on topic UAException -
Yes, 100 ms should be fine.
(repeating):
Can you please answer whether you have some of the following:
- high CPU load
- high number of threads or tasks in the process
- connecting to many server simultaneously,
- slow network connection to the server
- unusually "slow" server (server response)
I know that it is hard to quantify what constitutes "slow", but I am just looking for an opinion/general picture of your application.
07 Feb 2022 11:45 #10587 by andis59
Replied by andis59 on topic UAException -
At the moment I'm running on a KepserverEx in demo mode, which means that is will stop working after 2 hours...
I'm just preparing for the released version!
Yes, you can retry after at least slight delay (not immediately, in a "tight" loop).
What is a slight delay?
Will 100 ms work or do I have to wait longer?
// Anders
31 Jan 2022 19:27 #10579 by support
The exception should not , however, be normally happening unless there are some "real" problems. Can you please answer whether you have some of the following:
- high CPU load
If you have any of the above, it might be an issue we are looking at to address in version 2022.1.
29 Jan 2022 17:07 - 29 Jan 2022 17:09 #10572 by andis59
UAException - was created by andis59
I'm using QuickOPC version="5.63.0-rev3" and it's an WPF application made in C#
I get this exception now and then
OpcLabs.EasyOpc.UA.OperationModel.UAException
HResult=0x80131600
Message=An OPC-UA operation failure with error ID 'OpcLabs.UAEngine=4507' occurred, originating from '' and with depth of 1. The inner exception, of type "OpcLabs.EasyOpc.UA.Engine.UAEngineException", contains details about the problem.
Source=OpcLabs.EasyOpcUA
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.ReadValue(IEasyUAClient client, UAReadArguments readArguments)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.ReadValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor)
at OpcUa.OpcUaClient.ReadBool(String tag) in E:\Users\ame\source\repos\foo\DCSkyltLaser\OpcUa\OpcUaClient.cs:line 357
Inner Exception 1:
UAEngineException: Cannot lock the OPC-UA client session because it is not available.
The client method may be ReadValue, WriteValue, ReadMultiple, WriteMultiple,
The function that I have called OpcUa.OpcUaClient.ReadBool(String tag) is using ReadValue to read a boolean tag.
When this or other UAEceptions occurr: Is it enough to return an error and try to call the function again?
public bool ReadBool(string tag)
	bool result = true;
	try
		var server = _cfg.ServerUrl;
		UAEndpointDescriptor endpointDescriptor = new UAEndpointDescriptor(server);
		UANodeDescriptor tagNodeDescriptor = new UANodeDescriptor(_FromTags.GetTag(tag));
		result = (bool)_easyUAClient.ReadValue(
			 endpointDescriptor, tagNodeDescriptor
	catch (UAException uaException)
		Log.Fatal(uaException, $",Failure: {uaException.GetBaseException().Message}");
		result = false;
	return result;
Last edit: 29 Jan 2022 17:09 by andis59. Reason: Forgot to say version and WPF
