- Forum
- Discussions
- QuickOPC-UA in .NET
- Discovery, Browsing, Browse Dialogs and Controls
- Version 2023.1 Browsing for OPC UA Items - Exception
22 Sep 2023 05:16 #12213
by support
Replied by support on topic Version 2023.1 Browsing for OPC UA Items - Exception
Please do not report any more assembly loading exceptions until we get your project references & binding redirects fixed. I received your email with the new .vbproj and will respond.
22 Sep 2023 05:00 #12212
by micham
Version 2023.1 Browsing for OPC UA Items - Exception was created by micham
I am getting an exception when trying to browse OPC items. See below. My code is below. It is similar to your sample code in EasyOPCUADemo sample project.
Friend WithEvents uaDataDialog1 As OpcLabs.EasyOpc.UA.Forms.Browsing.UADataDialog
uaDataDialog1.EndpointDescriptor = "opc.tcp://DEV2017:48010"
If uaDataDialog1.ShowDialog() = DialogResult.OK Then
TempID = uaDataDialog1.NodeDescriptor.NodeId
End If
Exceptions
Type: System.TypeInitializationException
HResult: -2146233036 (0x80131534)
System.IO.FileLoadException: Could not load file or assembly 'Microsoft.Extensions.Logging.Abstractions, Version=3.1.28.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: 'Microsoft.Extensions.Logging.Abstractions, Version=3.1.28.0, Culture=neutral, PublicKeyToken=adb9793829ddae60'
at Opc.Ua.Utils..cctor()
=== Pre-bind state information ===
LOG: DisplayName = Microsoft.Extensions.Logging.Abstractions, Version=3.1.28.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
(Fully-specified)
LOG: Appbase = file:///D:/MyBin/Proj-VS2017/EBO-OPC Client/Configuration(4)/bin/x86/Debug/
LOG: Initial PrivatePath = NULL
Calling assembly : Opc.Ua.Core, Version=1.4.371.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8.
LOG: This bind starts in default load context.
LOG: Using application configuration file: D:\MyBin\Proj-VS2017\EBO-OPC Client\Configuration(4)\bin\x86\Debug\EBOOPCClientCFG.exe.Config
LOG: Using host configuration file:
LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config.
LOG: Post-policy reference: Microsoft.Extensions.Logging.Abstractions, Version=3.1.28.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
LOG: Attempting download of new URL file:///D:/MyBin/Proj-VS2017/EBO-OPC Client/Configuration(4)/bin/x86/Debug/Microsoft.Extensions.Logging.Abstractions.DLL.
WRN: Comparing the assembly name resulted in the mismatch: Major Version
ERR: Failed to complete setup of assembly (hr = 0x80131040). Probing terminated.
FileName: Microsoft.Extensions.Logging.Abstractions, Version=3.1.28.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
FusionLog:
(Fully-specified)
HResult: -2146234304 (0x80131040)
Message: Could not load file or assembly 'Microsoft.Extensions.Logging.Abstractions, Version=3.1.28.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Source: Opc.Ua.Core
StackTrace: at Opc.Ua.Utils..cctor()
TargetSite: Void .cctor()
DeclaringType: Opc.Ua.Utils
Module: Opc.Ua.Core.dll
Assembly: Opc.Ua.Core, Version=1.4.371.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8
CustomAttributes:
FullyQualifiedName: D:\MyBin\Proj-VS2017\EBO-OPC Client\Configuration(4)\bin\x86\Debug\Opc.Ua.Core.dll
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: e90038f5-d9d5-4c0c-b2e7-eda655301ec4
ScopeName: Opc.Ua.Core.dll
Message: The type initializer for 'Opc.Ua.Utils' threw an exception.
Source: Opc.Ua.Core
at Opc.Ua.Utils.SetTraceMask(Int32 masks)
at OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.InitializeSdkTrace()
at OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.InitializeSdk()
at OpcLabs.EasyOpc.UA.Toolkit.Client.UAClientEngineBase.InitializeSdk()
at OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.ConnectSdk()
at OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.InternalConnect()
at OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.Connect()
at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.InnerBrowseNodes(UABrowseArguments[] browseArgumentsArray, EasyUAAdaptableParameters adaptableParameters)
at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.BrowseNodes(UABrowseArguments[] browseArgumentsArray, EasyUAAdaptableParameters adaptableParameters)
at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.<InternalBrowseMultipleNodes>b__95_2(IReadOnlyList`1 list)
at OpcLabs.BaseLib.Collections.Generic.Extensions.IReadOnlyListExtension.IfThenElse[TInput,TOutput](IReadOnlyList`1 readOnlyList, Predicate`1 condition, Func`2 thenListSelector, Func`2 elseListSelector)
at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.InternalBrowseMultipleNodes(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.<>c__DisplayClass41_0.<BrowseMultiple>b__0()
at OpcLabs.BaseLib.Internal.DisposableObject.DisposeGuard[TResult](Func`1 func, Boolean throwOnDisposed)
at OpcLabs.BaseLib.Internal.DisposableObject.DisposeGuardNotNull[TResult](Func`1 func, Boolean throwOnDisposed)
at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.Implementation.ErrorTransformingEasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.Optimization.Implementation.RequestMergingEasyUAClient.<BrowseMultiple>b__1_0(UABrowseArguments[] array)
at OpcLabs.BaseLib.OperationModel.Extensions.IReadOnlyListOfOperationArgumentsExtension.MergingPerform[TArguments,TResult](IReadOnlyList`1 argumentsList, Func`2 arrayOperationFunction)
at OpcLabs.EasyOpc.UA.Optimization.Implementation.RequestMergingEasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.Implementation.LicensingEasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.Implementation.MultiplexingEasyUAClient.<>c.<BrowseMultiple>b__9_0(IEasyUAClient client, IReadOnlyList`1 list)
at OpcLabs.BaseLib.Collections.Generic.Extensions.IReadOnlyListExtension.SwitchCase[TInput,TOutput,TKey](IReadOnlyList`1 readOnlyList, Func`2 keySelector, IEqualityComparer`1 keyComparer, Func`3 outputSelector)
at OpcLabs.EasyOpc.UA.Implementation.MultiplexingEasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.Implementation.ForwardingEasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.EasyUAClient.BrowseMultiple(UABrowseArguments[] browseArgumentsArray)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.BrowseOne(IEasyUAClient client, UABrowseArguments browseArguments)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.BrowseOne(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UABrowseParameters browseParameters)
at OpcLabs.EasyOpc.UA.Browsing.Internal.UANodeBrowseable.BrowseNodes(Object parentNode, UABrowseParameters browseParameters, Predicate`1 nodePredicate, IEnumerable`1& leaves, IEnumerable`1& exceptions)
at OpcLabs.EasyOpc.UA.Browsing.Internal.UANodeBrowseable.BrowseBranches(Object parentNode, Object nodeFilter, IEnumerable`1& branches, IEnumerable`1& exceptions)
at OpcLabs.BaseLib.Forms.Browsing.Parts.ConditionalBrowseable.BrowseBranches(Object parentNode, Object nodeFilter, IEnumerable`1& branches, IEnumerable`1& exceptions)
at OpcLabs.BaseLib.Forms.Browsing.Parts.BrowseNodesControl.BrowseChildrenJob0(Object parameters)
at OpcLabs.BaseLib.Forms.Browsing.Parts.BrowseNodesControl.<>c__DisplayClass768_0.<CreateSafeBackgroundThread>b__0(Object obj)
at OpcLabs.BaseLib.Threading.Utilities.ThreadUtilities.<>c__DisplayClass1_1.<CreateProtected>b__1()
at OpcLabs.BaseLib.Extensions.Internal.ActionExtension.ProtectedInvoke(Action action, Boolean allowCancellation)
TargetSite: Void SetTraceMask(Int32)
CustomAttributes:
MetadataToken: 1
TypeName: Opc.Ua.Utils
End If
Exceptions
(Fully-specified)
FusionLog:
(Fully-specified)
Source: Opc.Ua.Core
CustomAttributes:
MetadataToken: 1
Source: Opc.Ua.Core
CustomAttributes:
MetadataToken: 1
- Forum
- Discussions
Time to create page: 0.092 seconds
