- Thank you received: 4
- Forum
- Discussions
- QuickOPC-UA in .NET
- Connections, Reconnections, Certificates
- Error connecting to Integration Objects UA Server BadCertificateUriInvalid
Any time you get this error, you need to check the own application certificate - ideally using the OPC UA Administration Dialog.
Further down in the exception, there is this piece of information which has everything in it already:
+ Application URI from the effective application manifest: uri:EBO-OPCClientCFG:MIKE2022
+ Own certificate subject URL name from certificate sub-id "": uri:mike2022:EBOOPCClientCFG:1.0.110.0
You need to fix the difference.
It looks like that you are now specifying the Application URI in the UA application manifest without the version number (which is fine - this is the approach we agreed on).
But there is still an old certificate present, and that one gets used (and it is different and it ) contains the version number
If you were deploying your app with old "scheme" of application URI and now are using a new scheme, everyone doing the upgrade will see the error once, and will need to regenerate the certificate (and then, possibly, reestablish the trust on the server side).
I am getting the error below while trying to connect to Integration Objects OPC UA Simulation Server. I am using QuickOPC NuGet version 5.71.401.
OPC UA service result - {BadCertificateUriInvalid}. The URI specified in the ApplicationDescription does not match the URI in the certificate. BadCertificateUriInvalid
OPC UA Expert can connect with no problems. See below.
Exception details:
Exceptions
OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80170000) in 'static Session.Create'. OPC UA service result - {BadCertificateUriInvalid}. The URI specified in the ApplicationDescription does not match the URI in the certificate. BadCertificateUriInvalid
+ Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.
+ This error can be reported by the OPC-UA server if the client application URI has changed but an old application instance certificate was kept. Try to remove and recreate the application instance certificate.
+ The client method called (or event/callback invoked) was 'BrowseMultiple[1]'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadCertificateUriInvalid}. The URI specified in the ApplicationDescription does not match the URI in the certificate. BadCertificateUriInvalid
Activity Trace:
Following (26) events were gathered during the action on activity ID [45], in the order of first occurrence:
SDK trace: Imported the PFX private key for [317EC45928DAB83209B9F3FBB73CD35DE2956C71].
2*Exception: {Opc.Ua.ServiceResultException} Certificate is not trusted.
SDK trace: Certificate Validation failed. Reason=BadCertificateUntrusted. [CN=Integration Objects UA Server Simulator] [5AC2015B6D938186041B856CCA48354F51DA3E48]
SDK trace: Validation errors suppressed: [CN=Integration Objects UA Server Simulator] [5AC2015B6D938186041B856CCA48354F51DA3E48]
SDK trace: CreateSession Called. RequestHandle=1, PendingRequestCount=1
SDK trace: ChannelId 0: in Connecting state.
[8] SDK trace: ChannelId 0: SendHelloMessage()
[12] SDK trace: ChannelId 0: ProcessAcknowledgeMessage()
[12] SDK trace: ChannelId 0: in Opening state.
[12] SDK trace: ChannelId 0: Token #0 created. CreatedAt=09:15:49.265. Lifetime=3600000.
[36] SDK trace: ChannelId 0: ProcessOpenSecureChannelResponse()
2*[36] Exception: {Opc.Ua.ServiceResultException} Certificate is not trusted.
[36] SDK trace: Certificate Validation failed. Reason=BadCertificateUntrusted. [CN=Integration Objects UA Server Simulator] [5AC2015B6D938186041B856CCA48354F51DA3E48]
[36] SDK trace: Validation errors suppressed: [CN=Integration Objects UA Server Simulator] [5AC2015B6D938186041B856CCA48354F51DA3E48]
[36] SDK trace: Security Policy: opcfoundation.org/UA/SecurityPolicy#Basic256Sha256
[36] SDK trace: Sender Certificate: [CN=Integration Objects UA Server Simulator] [5AC2015B6D938186041B856CCA48354F51DA3E48]
[36] SDK trace: ChannelId 9: Token #1 activated. CreatedAt=09:15:49.265. Lifetime=3600000.
[36] SDK trace: ChannelId 9: in Open state.
[36] SDK trace: ChannelId 9: Token Expiry 12/02/2023 10:15:49, renewal scheduled in 2699943 ms.
[12] SDK trace: ChannelId 9: ProcessResponseMessage()
2*Exception: {Opc.Ua.ServiceResultException} BadCertificateUriInvalid
SDK trace: CreateSession Completed. RequestHandle=1, PendingRequestCount=0, StatusCode=-2147483648
*Event list length limit exceeded*
Events starting with activity ID in [] may not necessarily be related to the current action.
ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: OpcLabs.UAEngine=1
((45, 1), Opc.Ua.TraceEventArgs)
((45, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
((8, 0), Opc.Ua.TraceEventArgs)
((12, 0), Opc.Ua.TraceEventArgs)
((36, 0), Opc.Ua.TraceEventArgs)
((36, 0), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
((45, 1), *Event list length limit exceeded*)
c3c0e69e-bf8f-4bfa-8e93-816783737e55: 45
8970fe52-aaa4-40f7-9a6e-74cdcee56724: static Session.Create
Error Code: 1
InnerException: OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadCertificateUriInvalid}. The URI specified in the ApplicationDescription does not match the URI in the certificate. BadCertificateUriInvalid
ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: Opc.UA.ServiceResult=0x80170000
Help Link:
Internal Code: 2148990976
Message: OPC UA service result - {BadCertificateUriInvalid}. The URI specified in the ApplicationDescription does not match the URI in the certificate. BadCertificateUriInvalid
Service Result: BadCertificateUriInvalid
Additional Info:
Description:
Inner Result:
Message: The URI specified in the ApplicationDescription does not match the URI in the certificate.
Qualified Symbolic ID:
Expanded Text:
Is Null: True
Is Standard: True
Name:
Namespace Index: 0
Namespace URI:
Namespace URI String:
Standard Name:
Status Code: BadCertificateUriInvalid
Code Bits: 32791
Code Bits Symbol: BadCertificateUriInvalid
Condition: 23
Description: The URI specified in the ApplicationDescription does not match the URI in the certificate.
Flag Bits: 0
Has Data Value Info: False
Info Type: NotUsed
Internal Value: 2148990976
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Semantics Changed: False
Severity: BadOrFailure
Status Info: Error
Structure Changed: False
Text: {BadCertificateUriInvalid}. The URI specified in the ApplicationDescription does not match the URI in the certificate.
Service Target Site: Void ValidateResponse(Opc.Ua.ResponseHeader)
DeclaringType: Opc.Ua.ClientBase
Module: Opc.Ua.Core.dll
Assembly: Opc.Ua.Core, Version=1.4.371.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8
CustomAttributes:
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: e90038f5-d9d5-4c0c-b2e7-eda655301ec4
ScopeName: Opc.Ua.Core.dll
Source: Opc.Ua.Core
Stack Trace:
at Opc.Ua.ClientBase.ValidateResponse(ResponseHeader header)
at Opc.Ua.SessionClient.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double requestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& revisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
at Opc.Ua.Client.Session.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double requestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& revisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double millisecondsRequestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& millisecondsRevisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.Open2(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales, Boolean checkDomain)
at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.<Create>d__4.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitSession.<Create>d__2.MoveNext()
TargetSite:
Message:
Source:
Stack Trace:
== Activity Trace ==
TargetSite:
Source:
TargetSite:
Any idea how to fix?
- Forum
- Discussions
