OPC Server Certficate Confirmation
18 Aug 2021 06:44 #10121 by support
In order to make the license purchase, visit www.opclabs.com/purchase/full-price-list . The easiest way is the choice (Web shop, credit card; license key generation is automated and usually happens within minutes).
17 Aug 2021 16:22 #10117 by aksenthil
Dear Team,
You are right.
the issue is resolved.
As you shared, after moving the certificate from Rejected folder to the UA Application folder in the same executable location, the issue was resolved.
Thanks for your support.
please share the procedure to purchase the license.
17 Aug 2021 15:28 #10116 by support
If you are targeting .NET Core, the certificate store directories are not the ones you have played with.
It is clearly documented in all the links I have provided. Please read it again.
The proper certificate store directories are "local", under the directory where your application executable is located.
17 Aug 2021 12:43 #10114 by aksenthil
Dear Team,
My application is OPC Dot net Core.
please find the shared image.
17 Aug 2021 06:43 #10113 by support
Does your application target .NET Framework or .NET Core? (please send a screenshot of the corresponding Project properties page - assuming that you are using Visual Studio - or a corresponding setting elsewhere).
15 Aug 2021 16:17 #10110 by aksenthil
Dear Team,
I moved the kepware UA Server certificate to the below folders
please find the screen shots
sameway, as per you r guidence, i moved the files to UA Application folder
please find below screen shot
sameway, the certificate at rejected folder is moved to "UA Certificate authorities" as well
i tried UA Configuration tool as well
after tried all the ways i trusted the certificate, still i am facing the below error
will it possible to authenticate.
can you share the steps to authenticate the certificate.
herevw with i attached the kepware certificate as well for your observation.
File Name: KEPServerE...0B1C.zip
File Size:1 KB
please let me know any other information you looking for to overcome this error.
10 Aug 2021 11:44 #10103 by support
If you trust that certificate, you should find it in the "Rejected certificate store" and move it into "trusted peers certificate store".
More information:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Instance%20Certificate.html
and possibly
- kb.opclabs.com/Using_OpcCmd_Utility_for_OPC_UA_Administration
10 Aug 2021 05:58 #10102 by aksenthil
Dear Team,
Thanks for Quick OPC UA Support. I can execute the OPC UA Client application.
But, while starting the application, I am getting the user confirmation request. Please find the below image.
How can I respond to this request?
Should I load the server certificate in the application path?
How can I feed the OPC server certificate to the quick OPC application?
Would you please help me to overcome this issue?
with regards,
senthil?
Time to create page: 0.070 seconds
