read Connectionstate
24 May 2021 12:50 #9698 by AdiROC
Replied by AdiROC on topic read Connectionstate
exactly what I was looking for, thank you!
code:
        public void initializeLogServer()
            EasyUAClient _client = new EasyUAClient();
            _client.ServerConditionChanged += ServerConditionChanged;
        private static void ServerConditionChanged(object sender, EasyUAServerConditionChangedEventArgs e)
            Debug.WriteLine(e);
            if(e.Connected == true)
                ValuesController.StateIO = true;
            else
                ValuesController.StateIO = false;
                if(e.ErrorMessage != null)
                    Log.Error(e.ErrorMessage);
24 May 2021 11:27 #9697 by support
The following user(s) said Thank You: AdiROC
24 May 2021 09:44 #9696 by AdiROC
read Connectionstate was created by AdiROC
Hello
In my Client Application, I need to know if the client is connected at the moment or not.
To achieve this, I wrote this code:
private static void EasyUAClientOnLogEntry(object sender, LogEntryEventArgs logEntryEventArgs)
            Debug.WriteLine(logEntryEventArgs);
            switch (logEntryEventArgs.EntryType.ToString())
                case "Information":
                    Log.Information(logEntryEventArgs.Message);
                    break;
                case "Warning":
                    Log.Warning(logEntryEventArgs.Message);
                    break;
                default:
                    Log.Debug(logEntryEventArgs.EntryType + ": " + logEntryEventArgs.Message);
                    break;
            if(logEntryEventArgs.Message.Contains("{BadTcpInternalError}") == true)
                Log.Error("OPCUA Client is not connected");
            else if (logEntryEventArgs.Message.Contains("has successfully connected") == true)
                Log.Information("OPCUA Client is connected");
Is there a better way to do this?
Thanks in advance!
