Certificate's signature algorithm
01 Jun 2020 10:14 #8531 by KrisSik
They are attached to this message.
01 Jun 2020 10:10 #8530 by support
can you please post your modified .config file as well? The problem is that I do not see the entries I expected in the trace file. So, I want to check if the .config file is OK.
01 Jun 2020 07:51 #8529 by KrisSik
Oops, forgot to attach the file.
01 Jun 2020 07:49 #8528 by KrisSik
I repeated those actions with enabled extended traces. Please, find the file with traces in the attachments.
Kristian
30 May 2020 05:58 #8526 by support
The certificate is probably being rejected for some reason, but the normal log entry do not contain enough information.
We need to go deeper. Can you please enable the extended tracing (kb.opclabs.com/QuickOPC:_How_to_enable_extended_tracing ) and provide us with the collected data.
Kind regards
29 May 2020 08:27 #8522 by KrisSik
Yes I did put the files in the following locations:
C:\ProgramData\OPC Foundation\CertificateStores\MachineDefault\private\MYH3 [2B62F0474B87FA86E543B61E6C1A4BC3D144D3C2].pfx
C:\ProgramData\OPC Foundation\CertificateStores\MachineDefault\certs\MYH3 [2B62F0474B87FA86E543B61E6C1A4BC3D144D3C2].der
C:\ProgramData\OPC Foundation\CertificateStores\UA Applications\certs\MYH3 [2B62F0474B87FA86E543B61E6C1A4BC3D144D3C2].der
And after connection attempt they are deleted and replace by the following newly generated certificate files:
C:\ProgramData\OPC Foundation\CertificateStores\MachineDefault\private\MYH3 [0083C1A616A2BBFA810632DDB116D3A1E451F42B].pfx
C:\ProgramData\OPC Foundation\CertificateStores\MachineDefault\certs\MYH3 [0083C1A616A2BBFA810632DDB116D3A1E451F42B].der
C:\ProgramData\OPC Foundation\CertificateStores\UA Applications\certs\MYH3 [0083C1A616A2BBFA810632DDB116D3A1E451F42B].der
Kristian
28 May 2020 17:44 #8520 by support
Let me repeat my question: Do you also put your certificate (as .DER, without private key) to the Trusted peers certificate store?
28 May 2020 12:43 #8519 by KrisSik
Let me describe the actions I did:
1. Placed the certificate (.pfx file) in the application instance certificate store.
2. Updated the EasyUAClient.SharedParameters.EngineParameters.ApplicationParameters.ApplicationName to match Common Name (CN) property from certificate's subject.
3. Initialized the EasyUAClient and tried to browse the node.
As a result, a new certificate is being generated and old one is deleted. The server's rejected certificates store contains already new generated certificate.
Please, find the logs file attached to this message.
Kristian
23 May 2020 11:32 #8502 by support
That is a complicated process, but in general, an existing certificate for the specified subject name should be kept (and not replaced) and used, as long as it itself validates (I think that it thus should also be in the Trusted store!) and fulfills additional conditions such as that the key size is not too low.
For initial diagnostics , please hook a handler to the (static) EasyUAClient.LogEntry event, and send us the events generated when QuickOPC replaces the certificate when it "should not. If there is a confidential information in it, email it to support09 (at) opclabs.com instead of posting here.
23 May 2020 10:11 #8500 by support
No, you cannot. QuickOPC relies on the behavior of UA Certificate generator (OPC Foundation) with most default settings.
QuickOPC will automatically create *some* certificate for you, without you having to specify anything, or allowing you to specify just the very basics (application name). This is an intentional design decision: There are so many ways and options the certificate can be generated, that even if we provided more option, there will always be somebody saying that they want their certificate be different.
If the certificate you get by the "automatic" process is not what you want, you need to generate one yourself by whatever means you choose, and then point QuickOPC to that certificate. This gives you total control of the certificate used, if you need it.
I understand from your other post that you have a problem with that approach as well, and I will reply to that post separately. But it is the right way to do it.
