ByteString type input in PHP
31 Aug 2022 07:40 #11079 by support
Thank you for update,
it is good to know!
31 Aug 2022 07:36 #11078 by novotnypetr
I must apologize, your solution from July 14th is functional and the code fragment which I sent on July 15th is working. (The problem "BadTypeMismatch" was in binary data structure.)
Thank you!
15 Jul 2022 11:53 #11048 by support
In order to be able to troubleshoot, I will need Wireshark capture ( kb.opclabs.com/Collecting_information_for_troubleshooting ) of what is happening when you run your PHP/QuickOCP program, and, if possible, a similar capture of what is happening with some other UA client that *does* work - if you have that. That is actually my question now too - do you have such client?
One of the reasons could be that with the way it is done now, the argument will be passed as array of bytes, which is not precisely the same as ByteString. However, AFAIK, compliant UA servers are required to treat them the same. But this is just a guess, there can be other reasons too.
15 Jul 2022 10:01 #11045 by novotnypetr
thank you for the answer, but it still doesn't work.
The code is now:
$fileContent = $this->getFileStream(); //binary data
$length = strlen($fileContent);
$bytes = [];
for ( $i = 0; $i < $length; $i++ ) {
  $bytes[] = ord($fileContent{$i});
$inputs = [
  0 => 1, //0 = target: production level, 1 = target: preparation level
  1 => 1, //Write machine part of the program: 0 = no, 1 = yes
  2 => 1, //Write robot part of the program: 0 = no, 1 = yes
  3 => 1, //Write freely configurable page part of the program: 0 = no, 1 = yes
  4 => $bytes //ByteString - Zipped program file to download
$typeFullNames = [
  0 => 'System.UInt16',
  1 => 'System.UInt16',
  2 => 'System.UInt16',
  3 => 'System.UInt16',
  4 => 'System.Byte[]'
$callArguments1 = new \COM("OpcLabs.EasyOpc.UA.OperationModel.UACallArguments");
$callArguments1->EndpointDescriptor->UrlString = $this->opcUaUrl;
$callArguments1->NodeDescriptor->NodeId->ExpandedText = "ns=2;i=399860";
$callArguments1->MethodNodeDescriptor->NodeId->ExpandedText = "ns=2;i=399790";
$callArguments1->InputArguments = $inputs;
$callArguments1->InputTypeFullNames = $typeFullNames;
$arguments = [
  0 => $callArguments1
$outputs = $opcUaClient->CallMultipleMethods($arguments);
Returning error message:
*** Failure Opc.UA.ServiceResult=0x80740000: OPC UA service result - {BadTypeMismatch}. The value supplied for the attribute is not of the same type as the attribute's value. [...]
The problem is again with the 4th parameter.
14 Jul 2022 10:31 #11042 by support
We do not provide paid support/consultations.
As you recognized, the issue here is that the type of the method's last input parameter needs to be correctly specified. That would be easy to do in QuickOPC for .NET, because it is possible to simply use the Type object that represents the right type (in C#, it would be typeof(byte[]) ). Unfortunately in COM tools (such as PHP), it is not directly possible to create/refer to .NET type objects, and that is one of the reason why the TypeCode-s are used; but then, they are limited and only allow scalars and not arrays.
But, I still think there is a way to do it. There are two parts to this:
1. You need to use CallMultipleMethods (as opposed to CallMethod) - even if you are making just one method call. The reason for it is that the CallMethod is an extremely simplified API with just a few arguments (and this limited functionality). It is a wrapper around CallMultipleMethods which constructs the right parameters for it. By using CallMultipleMethods , you get access to all options available. An example for this method is here: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...Call%20multiple%20methods.html . There is no PHP example but there are examples in other COM tools; I believe that should be enough.
2. Instead of using the UACallArguments.InputTypeCodes array, which suffers from the same limitation, you would use the UACallArguments.InputTypeFullNames array (opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...uments~InputTypeFullNames.html ). You need to give an array of strings, and each string will be the full .NET type name. In your example, the strings will be "System.UInt16", "System.UInt16", "System.UInt16", "System.UInt16", "System.Byte[]". Notice the angle brackets in the last element, which make it into an array type.
I have not tested this, but it should work.
The following user(s) said Thank You: novotnypetr
12 Jul 2022 08:35 #11035 by novotnypetr
this part of code executes the method:
$bytes = [];
$inputs = [
$typeCodes = [
  0 => 8, // TypeCode.UInt16
  1 => 8, // TypeCode.UInt16
  2 => 8, // TypeCode.UInt16
  3 => 8, // TypeCode.UInt16
  //4 => 6 //intentionally omitted because there is not type code for ByteString
$opcUaClient->CallMethod(
  $this->opcUaUrl,
  "ns=2;i=399860",
  "ns=2;i=399790",
  $inputs,
  $typeCodes
ByteString is 4th parameter as array of integers, so it is the same approach as in your example.
(Calling another method without byte string parameter work without problems, so the problem must be in the parameter.)
The error message is:
Source: OpcLabs.EasyOpcUA
Description: OPC UA service result - {BadInvalidArgument}. One or more arguments are invalid.
+ The method descriptor used was: NodeId="ns=2;i=399790".
+ The node descriptor used was: NodeId="ns=2;i=399860".
+ The client method called (or event/callback invoked) was 'CallMultipleMethods[1]'.
Is it possible to order an on-line consultation at your company? Maybe it will be faster to find a solution.
30 Jun 2022 16:15 - 30 Jun 2022 16:16 #11023 by support
I currently do not have a PHP example with method call and a ByteString, but we have an example of that with Write: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Write%20a%20ByteString.html . It looks like this:
// This example shows how to write a value into a single node that is of type ByteString.
$Values[0] = 11;
$Values[1] = 22;
$Values[2] = 33;
$Values[3] = 44;
$Values[4] = 55;
$Client = new COM("OpcLabs.EasyOpc.UA.EasyUAClient");
// Modify value of a node
try
    $Client->WriteValue(
    "opcua.demo-this.com:51211/UA/SampleServer", //or "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"
    "nsu=http://test.org/UA/Data/ ;i=10230",
    $Values);
catch (com_exception $e)
    printf("*** Failure: %s\n", $e->getMessage());
Does a similar approach work with method call? If not, what is the error your are getting?
Best regards/S pozdravem
Last edit: 30 Jun 2022 16:16 by support.
30 Jun 2022 12:49 #11022 by novotnypetr
in PHP project I need to call a method with a parameter of ByteString type (method for downloading programme to the machine from binary file). How to make this ByteString input parameter in PHP? Do you have any example code?
I tried various variants of array of bytes, but nothing works.
Time to create page: 0.243 seconds
