Could not create a certificate via a proxy
02 Dec 2021 16:35 #10421 by support
Start by adding an event handler to static event EasyUAClient.LogEntry.
Post here all the log messages generated.
There are two reasons for doing that:
1. The entries should (hopefully - depends on version) contain the name of the certificate file - which is the name you will need to give it if you create your own.
2. By a chance, there may be clues to the resolution of the actual problem you are seeing (but again, this diagnostics has been poorer earlier, and it has been improved in newer versions).
02 Dec 2021 16:17 #10420 by leinad
Maybe a solution could be to write tha certificate manually ... a suggestion on how to do it ?
02 Dec 2021 16:15 #10419 by leinad
Unfortunately we cannot upgrate it in short term (limits in the final installation environment): we bought the license on 12/2020, if you have any further suggestion we whould appreciate it (it is for sure a missing W10 PRO autorization).
02 Dec 2021 15:24 #10417 by support
unfortunately we cannot help with this, as the QuickOPC version is too old.
The suggestion is to upgrade to recent version first.
02 Dec 2021 15:05 #10416 by leinad
Our testing app cannot create a certificate (even connecting to the opcua.demo-this.com ) in the following environment: W10 PRO , .NET framework 4.0.30319, QuickOpc 553. No certficate is created in the proper directories (empty). Trapping of errors in the attache file. We also run the app as administor without success (in the past solved similar problems).
The same app runs without problems (creating automatically the certificate in the proper directory) in the following environment; W10, .NET framework 4.0.30319, QuickOpc 553.
File Name: ErrorVinicio1.rtf
File Size:14 KB
