MultipleItemChanged
08 Mar 2012 12:22 #791 by hedgehog
Replied by hedgehog on topic Re: MultipleItemChanged
That's works perfectly!
Thak you for all answers!!
08 Mar 2012 11:19 #790 by support
Replied by support on topic Re: MultipleItemChanged
If you want to call ReadMultipleItems periodically, you will need to write that code, based on timer event or so.
DAVtqResult does not contain ItemID, but it is the same ItemID as passed into the method in the element of an array with the same index as the result. That should normally be sufficient, as you can refer back to the input array, and take the ItemID from the corresponding element there. Some people do not like it that way, and want additional information (such as ItemID) "go through", appear in the results. If you require this, you can use the ReadMultipleItems overload that takes an input array of DAItemArguments objects, and each DAItemArguments has a State property which is an Object and you put there any data you like - e.g. an ItemID, or even a reference back to the same DAItemArguments object. The State is then available in each DAVtqResult after ReadMultipleItems method returns.
08 Mar 2012 10:52 #789 by hedgehog
Yes... it's the reason (first insert is ok). I should know it (even event name say it).
Thanks a lot for explanation!!
I have last question. Is there some function which read all items on every x time period (like ReadMultipleItems support.softwaretoolbox.com/ap...)?
How can I get TagID in results from DAVtqResults?
08 Mar 2012 10:21 #787 by support
Could it be the reason that many items actually do not change their values? (With some simplification, ) OPC Servers are required to send notifications only if the value or the quality have changed.
08 Mar 2012 09:50 #786 by hedgehog
Thank you for answer! Multiple items changed event handler works well.
Now I have another problem. In MultipleItemsChanged event (or in ItemsChanged event) I'm saving items into SQL database (with loop).
In DAItemGroupArguments I have 130 tags with update rates 5000ms for all tags.
I see there is only around 30 or 40 new inseted tag values in SQL database every 5s. I think there is tags saved within 1 second.
Is there some settings for DAClient which has dependence on my problem?
Do you suggest some another solution-function (not SubscribeMultipleItems)?
I use EasyOPC.NET 5.1 client (Windows form aplication).
15 Feb 2012 15:23 #771 by support
<span style="font-family: "Calibri","sans-serif"; color: #1f497d; font-size: 11pt; mso-ascii-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-themecolor: dark2">Hello,
<span style="font-family: "Calibri","sans-serif"; color: #1f497d; font-size: 11pt; mso-ascii-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-themecolor: dark2">For most usages, it is easier and fine to just use the ItemChanged event. You can freely use it even if you subscribe using SubscribeMultipleItems.
<span style="font-family: "Calibri","sans-serif"; color: #1f497d; font-size: 11pt; mso-ascii-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-themecolor: dark2">Every item change gets notified using BOTH ItemChanged and MultipleItemsChanged events. So you really just need to pick one which is better, but never use both together. If there are multiple changes arriving "together" from the OPC Server, it is slightly more efficient to hook to MultipleItemsChanged, because there is just one notification, and not say 100 notifications. Inside that handler, you then need to loop through the ArgsArray provided, and then process each object in the same way as you would do in ItemChanged event handler.
<span style="font-family: "Calibri","sans-serif"; color: #1f497d; font-size: 11pt; mso-ascii-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-themecolor: dark2">However, the performance difference is quite small in QuickOPC.NET (the event exists mainly for symmetry with QuickOPC-COM, where the EAsyDAClient object usually runs in a separate process, and method calls and event notifications are much costlier).
<span style="font-family: "Calibri","sans-serif"; color: #1f497d; font-size: 11pt; mso-ascii-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-themecolor: dark2">An example for MultipleItemsChanged is in the Reference documentation for that event. It looks like this:
// This example shows how to process multiple item changes in one callback.
using System;
using System.Threading;
namespace DocExamples
namespace _EasyDAClient
class MultipleItemsChanged
public static void Main()
using (var easyDAClient = new EasyDAClient())
easyDAClient.MultipleItemsChanged += easyDAClient_MultipleItemsChanged;
easyDAClient.SubscribeMultipleItems(
new[] {
new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Simulation.Random", 1000, null),
new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Trends.Ramp (1 min)", 1000, null),
new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Trends.Sine (1 min)", 1000, null),
new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Simulation.Register_I4", 1000, null)
Console.WriteLine("Processing multiple item changed events for 1 minute...");
Thread.Sleep(60 * 1000);
// Multiple items changed event handler
static void easyDAClient_MultipleItemsChanged(object sender, EasyDAMultipleItemsChangedEventArgs es)
Console.WriteLine();
EasyDAItemChangedEventArgs[] a = es.ArgsArray;
foreach (EasyDAItemChangedEventArgs e in a)
Console.WriteLine("{0}: {1}", e.ItemDescriptor.ItemId, e.Vtq);
15 Feb 2012 08:09 #770 by hedgehog
MultipleItemChanged was created by hedgehog
I want to know what is difference between ItemChanged event and MultipleItemsChanged event for easyDAClient.
Now I'm using easyDAClient_Item changed. In base I call function easyDAClient.SubscribeMultipleItems(DAItemGroupArgumets...) in Windows Form Application.
Is there some example for MultipleItemsChanged event (I didn't found any example on internet for now)?
How does it work?
How can I get results (for ItemChanged event I get results for one tag in e.Vtq..., e.ItemDescriptor... )?
Thanks & Best regards
