Writting in a Arrayvariable with OPC UA
21 Apr 2022 11:09 #10817 by support
writing an array isn't much different from writing a scalar value:
' This example shows how to write a value into a single node that is an array of Int32.
Imports OpcLabs.EasyOpc.UA
Imports OpcLabs.EasyOpc.UA.OperationModel
Namespace UADocExamples._EasyUAClient
    Partial Friend Class WriteValue
        Public Shared Sub ArrayOfInt32()
            ' Define which server we will work with.
            Dim endpointDescriptor As UAEndpointDescriptor =
                    "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"
            ' or "http://opcua.demo-this.com:51211/UA/SampleServer" (not in .NET Standard)
            ' or "https://opcua.demo-this.com:51212/UA/SampleServer/"
            ' Instantiate the client object
            Dim client = New EasyUAClient()
            ' Modify value of a node
            Try
                ' // /Data.Static.Array.Int32Value
                Dim arrayValue = New Int32() {11111, 22222, 33333, 44444, 55555, 66666, 77777}
                client.WriteValue(endpointDescriptor, "nsu=http://test.org/UA/Data/ ;i=10305", arrayValue)
            Catch uaException As UAException
                Console.WriteLine("*** Failure: {0}", uaException.GetBaseException.Message)
                Exit Sub
            End Try
        End Sub
    End Class
End Namespace
21 Apr 2022 07:31 - 21 Apr 2022 08:38 #10816 by Nordmann447
HI,
i tried to write into a Arrayvariable but i cant find the correct Code in the discription.
Reading a array was not a Problem, i write something like that:
Dim Variable As UAAttributeData = EasyUAClient1.Read(KommunikationServer, NoteID())
lable1.text = Variable.value(5)
Do you have a simply Code to write in a Arrayvariable?
Last edit: 21 Apr 2022 08:38 by Nordmann447.
