Error when subscribing multiple items
16 Nov 2020 14:23 #9151 by janderscu
Version info below:
1. OpcLabs.EasyOPCClassic.dll - 5.55.422.1 (part of QuickOPC 2019.1)
2. Win Ver - Windows 10 Pro - Build 19041.508
16 Nov 2020 08:17 #9148 by support
please provide:
1. Version of QuickOPC your are using, including the build number (best way to find: locale one of the OpcLabs.*.dll assemblies in Windows Explorer, right-click on it, select Properties, and find the version on the Details tab).
2. Version of Windows - from the WINVER command.
16 Nov 2020 00:36 #9147 by janderscu
I have written a custom OPC classic client in .Net C#. When subscribing multiple items, I get the following error below. I can use other third-party OPC explorer apps to successfully view the servers available and read items. I put try/catch blocks in my own code to attempt to catch it and display additional errors, but nothing is caught in the main code. I think is getting returned straight from the Quick OPC API. FYI, I have run this code on other machines and successfully subscribed to data there, so I do believe it is something unique to this machine. However, any information that can be inferred from that error message that could help me narrow down the problem would be greatly appreciated.
Unhandled Exception: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at QueryMultipleInterfaces(IUnknown* pUnknown, UInt32 cMQIs, tagMULTI_QI* pMQIs)
at VaryingQueryMultipleInterfaces(IUnknown* pUnknown, UInt32 cMQIs, UInt32 cComSupports, CComSupport** pComSupports, tagMULTI_QI* pMQIs, CComSupport** pComSupportChosen)
at COCKMachine.ConnectServerList(COCKMachine* )
at COCKMachine.ExecuteConnect(COCKMachine* )
at CMachine.Connect(CMachine* )
at CConsumer.RequestMachine(CConsumer* , CMachineClient* pMachineClient, CMachine** pMachine, Boolean AutoDisconnect)
at CClient.ConnectMyMachine(CClient* )
at CClient.ExecuteConnect(CClient* )
at COCKClientBase.ExecuteConnect(COCKClientBase* )
at CAbstractClient.HandleConnectRequest(CAbstractClient* )
at COCKClient.ReceiveAndProcessRequests(COCKClient* )
at COCKClient.ExecuteWork(COCKClient* )
at CAbstractClientWorkerThread.execute(CAbstractClientWorkerThread* )
at CBasicWorkerThread.perform(CBasicWorkerThread* )
at CBasicWorkerThread.process(CBasicWorkerThread* )
at CBasicWorkerThread.threadProc(Void* lpParameter)
THis is my code for adding event handler and subscribing:
static void GetData_DA()
            // Dictionary<System.Guid, OpcLabs.EasyOpc.ServerElement> d = new Dictionary<System.Guid, OpcLabs.EasyOpc.ServerElement>();
            EasyDAItemChangedEventHandler eventHandler = new EasyDAItemChangedEventHandler(client_ItemChanged_DA);
            try
                for (int j = 0; j < addressArray.Count; j++)
                    clients_DA[j].ItemChanged += eventHandler;
                Console.WriteLine("Subscribing item...");
                int k = 0;
                    var argumentArray = new DAItemGroupArguments[(Int16)chanCountArray[j]];
                    string address = (string)addressArray[j];
                    string hostname = address.Split(",".ToCharArray())[0];
                    string servername = address.Split(",".ToCharArray())[1];
                    for (int i = 0; i < (Int16)chanCountArray[j]; i++)
                        int requestedUpdateRate = Convert.ToInt32(scanRateCopy * 1000);
                        //Console.WriteLine(labelListCopy.GetValue(k).ToString());
                        argumentArray[i] = new DAItemGroupArguments(hostname.Trim(), servername.Trim(), labelListCopy.GetValue(k).ToString(), requestedUpdateRate, k);
                        k++;
                    Console.WriteLine("HERE1");
                    int[] error = clients_DA[j].SubscribeMultipleItems(argumentArray);
                    Console.WriteLine("HERE2 " + error[0].ToString());
            catch (Exception ex)
                Console.WriteLine("GetData_DA error : " + ex.ToString());
        static void client_ItemChanged_DA(object sender, EasyDAItemChangedEventArgs e)
            if (e.Succeeded)
                Console.WriteLine("{0}: {1}", e.Arguments.ItemDescriptor.ItemId, e.Vtq);
            else
                Console.WriteLine("{0} *** Failure: {1}",
                e.Arguments.ItemDescriptor.ItemId, e.ErrorMessageBrief);
