Change shared parameters on the EasyDAClient causes exception
08 Feb 2020 10:04 #8210 by support
there are two things here: Actually, you really are supposed to set any of the static parameters just once, before the first instance is created or any of the static methods is called. Not sure how well it is documented, but it the case by design.
On the other hand, when you fail to do so (as it was your case originally), the QuickOPC behavior should not precisely be as you have described. Either the changes after certain point should be ignored, or there should still be InvalidOperationException, but not from the place (call stack) it has happened.
Since this is a minor problem, we will make a note but do not expect a fix any time soon.
The following user(s) said Thank You: Andriy
07 Feb 2020 11:36 #8208 by Andriy
I get InvalidOperationException when apply shared parameter on the EasyDAClient class after a first instance of it is created.
The error disappeared when I changed the order
I configured shared parameter as recommended in the following topic
Subscription mode. Catastrophic failure error
              EasyDAClient.ClientParameters.LinkCallbackQueueSize = 500000;
              EasyDAClient.ClientParameters.RequestQueueSize = 500000;
              EasyDAClient.ClientParameters.ResponseQueueSize = 500000;
              EasyDAClient.EngineParameters.TopicLruSize = 500000;
              EasyDAClient.EngineParameters.DefaultEventQueueSize = 500000;
OPC library build 5.56.1055.1
Call stack:
System.InvalidOperationException: Handle is not initialized.
   at System.Runtime.InteropServices.GCHandle.FromIntPtr(IntPtr value)
   at gcroot<System::Object ^>..PE$AAVObject@System@@(gcroot<System::Object ^>* )
   at OpcLabs.EasyOpcRaw.DataAccess.CDAInnerEngine._GetSharedParameters(CDAInnerEngine* )
   at OpcLabs.EasyOpcRaw.DataAccess.DAInnerEnginePropertyUpdater.SharedParametersOnPropertyChanged(Object sender, PropertyChangedEventArgs eventArgs)
   at OpcLabs.EasyOpc.DataAccess.Engine.EasyDASharedParameters.OnPropertyChanged(String propertyName)
   at OpcLabs.EasyOpc.Engine.EasyClientParameters.OnPropertyChanged(String propertyName)
