DA-XML: SubscribeItem with percentDeadBand causes COM exception
18 Dec 2019 08:33 #8091 by support
please use:
        Client.SubscribeItem(
                "http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx",
                "Dynamic/Analog Types/Double",
                new DAGroupParameters(1000, 0.01F),
                (_, args) => Console.WriteLine(args.Exception ?? args.Vtq?.Value),
                null);
The following user(s) said Thank You: goosvanbeek
17 Dec 2019 21:13 #8090 by goosvanbeek
Hello support,
Windows 10 IOT Enterprise and Windows 10 Enterprise
QuickOPC 5.56.475.1
Visual Studio 2019
Exception: System.Runtime.InteropServices.COMException (0x800401F3): Invalid class string
I'm using code as the test example below (for years). Subscribing with the first method works well, the second one causes a COMexception. (test project attached)
This issue occurred after rebuilding my application. On every Win10 machine I test it on. I uninstalled the latest Windows security updates, without result.
Is there a solution to solve this issue?
Goos van Beek
namespace ConsoleApp1{
    #region usings
    using System;
    using OpcLabs.BaseLib.ComInterop;
    #endregion
    class Program{
        private static readonly EasyDAClient Client = new EasyDAClient();
        static void Main(){
                "Dynamic/Analog Types/Int",
                1000,
                (_, args)=>Console.WriteLine(args.Vtq?.Value),
                null);
            // System.Runtime.InteropServices.COMException (0x800401F3): Invalid class string
                string.Empty,
                VarTypes.Empty,
                1000,
                0.01F,
                (_, args)=>Console.WriteLine(args.Exception ?? args.Vtq?.Value),
                null);
            Console.ReadKey();
 [attachment=821]ConsoleApp1.zip[/attachment]
