Newbie Question #2: Concsistent data-transfer
18 Jan 2016 16:13 #3786 by support
You are right in the sense that if you really want the guarantees, then you have to go the way with Device reads. I am just saying what the recommendations are; they exist for a reason (performance, blocking, ...).
OPC DA does not address the atomicity issue outside of a single item. It is either not achievable at all, or is vendor-specific. Inside a single item (value), even when it is a complex data type (such as an array or string), I would expect it to be a consistent reading of device values, and it probably says so somewhere in the OPC specs, but I cannot provide an evidence to that out of my head.
18 Jan 2016 16:02 #3784 by Hanssing
support wrote: - in DAReadItemArguments.ReadParameters. DAReadItemArguments are passed to EasyDAClient.ReadMultiple[Values].
- in some EasyDAClient.ReadItem[Value] overloads: they take DAReadParameters as an argument.
Thanks, did not find it in concepts, but I kinda figured it would be there since teh structure still existed. I will try it our.
support wrote: Note that use of Device reads (and especially Sync ones) is considered a bad practice in OPC.
Yes, but they are usefull if you want a responsive application.
How else would you ensure Device-initiated consistent transfer of multiple values?
- All data have time-stamps newer than Flag transfer-trigger or older by more than Age-value?
Can we in general be sure that OPC-reads/subscriptions of complex data-types (Arrays, strings etc) are atomic in nature or is this vendor-specific from Device to Device?
Hanssing
18 Jan 2016 15:21 #3783 by support
The functionality you refer to has not been removed, the parameter has just been moved to a different object. It is now in DAReadParameters.DataSource.
You can set this e.g.
18 Jan 2016 14:35 #3780 by Hanssing
I the old days, there was a DeviceRead-method which could be used to ensure consistent, immediate and current datatrasfer:
EasyDaClient.ClientMode.DataSource = DADataSource.Device;
This was changed in newer versions og the library.
How does one ensure consistent transfer of multiple items including the read-order in newer versions where this method has been removed?
Example:
PLC assigns data (In time-order) to ItemA, ItemB, ItemC, and afterwards signals New Data available in FlagD
OPC-application should read (in time-order) FlagD, ItemC, ItemB, ItemA
If FlagD is signalled, then data data allways contain consistent values.
If using subscription, then the application would have to wait a full agetime after seing the signal before data would be consistent. So the transfer-cycle is two times longer than it actually needs to be.
Can a reading of certain subscribed values be forced ?
Or can the behavior of DeviceReads be triggered somehow?
Hanssing
