Using ReadItemValue with OpcLabs.EasyOpcClassic.dll under WPF access issue
28 Jul 2015 04:20 #3464 by support
This is an extension method, which I think is located in the IEasyDAClientExtension class in the EasyOpcClassicInternal assembly (cannot check that at the moment).
It is basically a thin wrapper over ReadMultipleItemValues, implemented as a static method in a static class, and taking any IEasyDAClient (including EasyDAClient) as the first argument.
Let me know if you need more info.
28 Jul 2015 01:12 #3463 by pgilbert
Hello, while using the version 5.34.274.1 of OpcLabs.EasyOpcClassic.dll our interpreted language cannot reach the ReadItemValue method that is supposed to be in the namespace OpcLabs.EasyOpc.DataAccess.EasyDAClient . However the ReadMultipleItems and ReadMultipleItemValue are accessible.
Inspecting the assembly with Telerik JustDecompile confirms that the method ReadItemValue is not part of that namespace. I must say that the Visual Studio example is working:
using System.Windows;
namespace WpfApplication1
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
        private void Window_Loaded(object sender, RoutedEventArgs e)
            var value = client.ReadItemValue("", "OPCLabs.KitServer.2", "Demo.Single");
            TextBox1.Text = (value== null) ? "" : value.ToString();
Question: What does need to be done to access that method when not using Visual Studio or alternatively where is it located ?
Thanks in advance,
