OPC Client for :NET stops Read
14 Mar 2014 14:14 #1771 by support
OK, the reply does not contain the full information (build number), but for now it is sufficient.
This is very difficult to diagnose without having it reproduced.
Can you "Break" the program into the debugger when this happens, and verify that the execution is truly stopped inside the statement you suspect, and capture the call stack?
14 Mar 2014 09:40 #1770 by barbieri
VERSION IS 5.23
thanks
matteo
14 Mar 2014 09:02 #1769 by support
which version and build of QuickOPC are you using please? (one way to find out is to right-click one of its assemblies in Windows Explorer, select Properties, then view the version info on the Detail tab).
14 Mar 2014 08:46 #1768 by barbieri
I've a .NET application that read everytime a list of TAGS on a Siemens PLC.
After some time the application start a Read Item Value operation but does not give any result.
Also no timeout happened.
My application runs on a pc with WIndows 7.
I initialize the OPC as follows:
MyEasyDAClient = new OpcLabs.EasyOpc.DataAccess.EasyDAClient();
EasyDAClient.SharedParameters.Machine.MachineReconnectDelay = 1000;
MyEasyDAClient.InstanceParameters.Mode.AllowAsynchronousMethod = true; // false
MyEasyDAClient.InstanceParameters.Mode.AllowSynchronousMethod = true;
MyEasyDAClient.Isolated = true;
MyEasyDAClient.InstanceParameters.HoldPeriods.ItemDetach = 5000;
MyEasyDAClient.InstanceParameters.HoldPeriods.ServerDetach = 30000;
MyEasyDAClient.InstanceParameters.HoldPeriods.TopicRead = 5000;
MyEasyDAClient.InstanceParameters.HoldPeriods.TopicWrite = 5000;
MyEasyDAClient.InstanceParameters.UpdateRates.ReadAutomatic = 10000;// Timeout.Infinite;
MyEasyDAClient.InstanceParameters.UpdateRates.WriteAutomatic = -1;// Timeout.Infinite;
MyEasyDAClient.InstanceParameters.Mode.DesiredMethod DAReadWriteMethod.Synchronous;
MyEasyDAClient.SynchronizationContext = dispatcherSynchronizationContext1;
MyEasyDAClient.InstanceParameters.Timeouts.BrowseAccessPaths = 10000;
MyEasyDAClient.InstanceParameters.Timeouts.BrowseNodes = 25000;
MyEasyDAClient.InstanceParameters.Timeouts.BrowseProperties = 20000;
MyEasyDAClient.InstanceParameters.Timeouts.BrowseServers = 20000;
MyEasyDAClient.InstanceParameters.Timeouts.GetProperty = 10000;
MyEasyDAClient.InstanceParameters.Timeouts.ReadItem = 10000;
MyEasyDAClient.InstanceParameters.Timeouts.WriteItem = 10000;
I tried with Syncronous and Asyncronous method without any change.
The function that I use to read is this:
public static object ReadItemValue(string Machine, string Server, string TAG)
object obj = null;
try
m_Mut.WaitOne();
if (OpcInitialized)
obj = MyEasyDAClient.ReadItemValue(Machine, Server, TAG);
else
throw new SVException(LoadStringWithModuleName("A100_007"));
catch (Exception ex)
throw new Exception(LoadString("A102_177") + "TAG:" + TAG, ex);
finally
m_Mut.ReleaseMutex();
return obj;
Everything seems to stop at " obj = MyEasyDAClient.ReadItemValue(Machine, Server, TAG);" without any error.
Matteo
