Unable to Connect ORB in .Net Service
29 Apr 2024 11:42 #12738 by Jannie@Moore
Problem was resolved, our OPC were 32bit we had to publish our application as 32bit
25 Apr 2023 09:24 #11702 by support
I have some questions.
1. I am making an assumption that by "ORB", you mean MatrikonOPC Redundancy Broker. Is that correct?
2. Which version of the ORB are you using?
3. Which version of QuickOPC are you using?
4. Is you project targeting .NET Framework, .NET Core, or .NET 6+?
25 Apr 2023 08:56 #11699 by Jannie@Moore
Hi there, we have build windows service in .net, we can connect to Simulation Server , We can connect to Tunneller.
But we cannot connect to ORB.
We get below error
[04/25/2023 10:36:03] - DataChangeNotification (PROCESS_CONTRL.771PIC0603_PV_OS *** Type: System.NotSupportedException *** Failure: The COM server does not support the interface 'OpcRcw.Da.IOPCItemProperties'.
This problem could be caused by:
- incorrectly installed proxy/stubs.
- problems with the DCOM security settings.
- a personal firewall (sometimes activated by default).
+ The client method called (or event/callback invoked) was 'ItemChanged'.
+ The client method called (or event/callback invoked) was 'ItemChanged'.)
