× The UADemoPublisher program (console application) is a demonstration publisher for OPC UA PubSub.
delta frames with UADemoPublisher
22 Feb 2022 12:19 #10647 by support
I have checked the source code, in order to get the precise picture. Here is how it works:
* FixedLayoutPubSubConnection (FixedLayoutGroup): For all writers, KeyFrameCount is applied only when the transport uses JSON (not for UADP).
* FlexibleLayoutPubSubConnection (FlexibleLayoutGroup): For all writers, KeyFrameCount is applied only when the transport uses JSON (not for UADP).
* DynamicLayoutPubSubConnection (DynamicLayoutGroup): For all writers, KeyFrameCount is applied (both with JSON and UADP).
There were some reasons to do it this way; they had to do with the fact that the design of the writer groups/dataset writers comes from an initial OPC UA PubSub PlugFest, where it was/is required from the participants to use certain settings (there was some freedom, and that's we we tried to capture with the configurable options, but some settings were mandatory). I am hesitant to make a change to the UADemoPublisher that would not be backward compatible. But, if you describe to me what is it that you are trying to achieve/test, perhaps I could add something to allow that, in a compatible way.
22 Feb 2022 08:12 #10645 by Ehmsen
I am trying to use your UADemoPublisher in order to verify my implementation of subscribing delta frames. I can see delta frames coming from the DynamicLayoutConnection, but not from the FlexibleLayoutConnetion, even if I pass '-kfc 10'. Is it not applicable? If so, can you explain why? Otherwise, what am I missing to make FlexibleLayoutConnetion send delta frames?
