DAConnectivity with QuickOPC-2018.3
09 Jan 2019 14:38 #6968 by treams-gmbh
that was the problem.
Thanks a lot
09 Jan 2019 13:52 #6967 by support
09 Jan 2019 12:50 #6966 by treams-gmbh
thank you for the quick reply.
1. Visual Studio 2017 Community
2. .NET Framework 4.6.1
3. Yes it is a Windows Form Project
4. I try to drag BindingExtender from QuickOPC Tools to my Form and nothing happens. Normally I should see the BindingExtender Icon next to the DaConnectivty Instance (daConnectivity1). It's the same with the PointBinder (See attached screenshot).
Everything worked fine with QuickOPC-2018.2
09 Jan 2019 12:23 #6965 by support
Can you please answer:
  1. Which version of Visual Studio are you using?
  2. In Project Properties of your project, what is the target version of the .NET Framework?
  3. I assume that it is a Windows Forms project - please confirm.
  4. Please explain "It's also not possible to add these 2 QickOPC tools manually." - what happens, why is it not possible?
09 Jan 2019 10:36 #6964 by treams-gmbh
I used for testing the 2018.2 Version until I got the message that the total days are expired. After I downloaded and install the latest Version 2018.3 I can't implement the DAConnectivity from toolbox. In the 2018.2 Version it automatically adds the BindingExtender and PointBinder. It doesn't work in the latest version. It's also not possible to add these 2 QickOPC tools manually.
Is there anything that i can do?
best regards
