Publickey of DLLs when using disabled prerequisites boxing
27 Mar 2020 11:01 #8333 by support
Sent QuickOPC 2020.2 alpha version link + evaluation license by email.
26 Mar 2020 06:53 #8329 by zaglerp
We have a test setup using several OPC-Servers and our OpcLabs-based client. The exceptions occured here approx. once per day. If you are interested we can run tests using a preliminary release here.
26 Mar 2020 06:53 #8328 by support
We will take over the whole current state of UA-.NET-Legacy into QuickOPC 2020.2.
26 Mar 2020 06:45 #8327 by zaglerp
Yes, we need the second commit, i.e.
github.com/AlinMoldovean/UA-.NET/commit/29208043d338c967537615419367f81b48d78231
25 Mar 2020 18:42 #8326 by support
I had a somewhat deeper look into this.
There seem to be at least two changes made to address github.com/OPCFoundation/UA-.NET-Legacy/issues/1 .
The first is github.com/OPCFoundation/UA-.NET-Legacy/commit/552f5c2d8eed8df3eb34d1d00edafa82884e2707 . We already have this one in QuickOPC, because we are using the 1.03.342 release.
The second is github.com/AlinMoldovean/UA-.NET/commit/29208043d338c967537615419367f81b48d78231 .We do not have this second one in QuickOPC currently (it is not part of any release on GitHub yet).
Are you saying that to fix your problem, you need the second one too?
25 Mar 2020 17:01 #8324 by support
We might take over the modified OPC Foundation code for the upcoming QuickOPC version (2020.2). Tentatively, it may be released in 2-4 weeks, but do not take it as a promise. If your problem is truly caused by that issue in the UA stack, and it has been fixed on GitHub, it should go away.
Nobody has a support contract with us, we do not offer that. We have "upgrade assurance", which allow cost-effective access to newly released versions, but that is unrelated to support. The way we do support is that we support everybody to maximum reasonable/viable extent, but we provide no guaranteed support.
If you do not have upgrade assurance covering the date of us releasing the new version, you will need to purchase a version upgrade in order to use it.
25 Mar 2020 16:10 #8323 by zaglerp
Understood. This DLL is part of your product and we cannot change it.
Our core problem are exceptions coming from your OPC stack, just as described here:
www.opclabs.com/forum/ua-general/2444-opc-ua-bindings-tcpasy...timeout-system-object?start=10
These exceptions happen multiple times per day. Our software is running at a major automotive company in Germany and we have to improve the situation as soon as possible. Our applications terminates several times per day.
This error has already been fixed at OPC foundation (see github.com/OPCFoundation/UA-.NET-Legacy/issues/1), but your SDK does not include this fix since was OPC foundation did not release it.
We would prefer to get a updated version of QuickOPC, which includes this fix.
We are aware that we do not have an active support contract. Any suggestions to solve these problem (technical and commercial) are welcome.
We can have a personal telephone call (or Skype) if this helps to solve the problem.
Kind regards
Peter
25 Mar 2020 14:15 #8322 by support
You cannot do that.
You have purchased a product of ours, which includes some 3rd party libraries. This is also the case of certain OPC Foundation libraries you are referring to.
We are signing them with our key (they came unsigned by OPC Foundation), because strong-named assemblies (which is a requirement by many customers) of QuickOPC can only reference strong-named assemblies as well.
As a side note, of course we would not be willing to provide any support if what you are using was not what we have assembled as a product.
If there is a need to change something, it'll have to be done by us.
Very importantly though, there are also various licensing restrictions. It is complicated, but here are some (simplified) that you need to be aware of (in my understanding, IANAL):
- If we, as OPC Foundation Members, make a change to the code of those libraries, we need to provide that change back to OPC Foundation (RCL license). That would not be technically impossible, but we have a policy that we do not make such changes if at all avoidable.
- You (I suppose you are not an OPC Foundation Members) cannot use the UA stack source code that you get from OPC Foundation in your product without making source code of your product, and any modified libraries, public (GPL). See opcfoundation.org/license-agreement/ .
25 Mar 2020 13:52 #8321 by zaglerp
Thank you,
We have to apply a patch to this DLL, how can we do that?
Kind regards
Peter
25 Mar 2020 12:31 #8320 by support
You are not supposed to do this.
Time to create page: 0.071 seconds
