Using separate instances of EasyDAClient object
27 May 2012 13:07 #868 by support
P.,
There really is no benefit in using separate instances of EasyDAClient object, in terms of performance, reliability etc. On the other hand, there is also no harm - and, if, for example, using separate objects somehow makes the application logic more streamlined, and the coding easier, then go for it, and create multiple EasyDAClient objects as you need.
Zbynek Zahradnik
Original Message
Sent: Saturday, March 31, 2012 7:32 AM
Subject: OpcDAClient Monitoring
Zbynek
I have taken your advice by inferring that a quality value of zero on every signal being monitored infers a loss of comms to the plc.
At the moment I have all 30 variables being monitored for change via a single instance of an OpcDAClient using the
publicvoid opcDAClient_PlcDataChanged(objectsender,EasyDAMultipleItemsChangedEventArgs es) event handler.
Of these, some will change more often than others but at the moment, a change in any one results in multiple checks on the item ID returned so that it can decide on which display value to update. It works fine, but I wondered if there were benefits in breaking up the values into 2 or 3 groups, ie and have them monitored by separate instances of an opcDAClient.
P.
Time to create page: 0.048 seconds
