Visual studio exemple debug crash
14 Oct 2020 15:36 #8999 by support
Unfortunately I do not have more to offer, besides to recommend to install on a fresh new computer.
I am also not sure whether the issue has directly anything to do with us, because MSBuild should not be running any code from our components. If anything, it should only be using it to make the build.
13 Oct 2020 09:38 #8995 by PhilippeG
Nota : I have Visual Studio 2013 and Visual Studio 2019 on my computer
13 Oct 2020 08:41 #8994 by PhilippeG
I uninstalled QuickOpc,
deleted the cache of VisulStudioToolBox (*.tbd)
deleted all references to OPclabs in the windows registry,
I installed again but that doesn't work : I added EasyDAClient component in the VisulStudio ToolBox,
but when I launch the project in debug, it crashes ('Msbuid stopped working') Exception Code 0xc0000005
05 Oct 2020 11:59 #8967 by support
Thank you for additional details.
The fact that uninstall has left icons in the Toolbar is a known issue. The workaround is either right-click in the Toolbox and do "Reset Toolbox", or, if that does not help, delete the unwanted icons one by one manually. The fact that they show up should not, however, be - by itself - a cause for the crashes you are observing. On the other hand, some kind of version mixup can be the cause (this is not to say that you did anything wrong).
Do you have only "OPC Labs QuickOPC 2020.2" under "Program Files (x86)", or is there some other similar folder, with different version number?
If so, can you remove it?
02 Oct 2020 12:29 #8963 by PhilippeG
I modify the configuration file for devenv.config,
it doesn't work
I had installed an older version (i don't remember the version), but I uninstalled it before I installed the new version
After the uninstall, the controls are still visible in the visual studio toolbox (VS2019 professional)
I reinstalled quick Opc 2020.2
The controls in toolbox in the designer are not all registered. Some are missing. See attachements
I tested two type of window form project (framework 4.7.2)
-project with form contains a opcbrowsecontrol control in the designer : the debug crash ('Msbuid stopped working'), but the process never stopped
(i have to kill Visual Studio process to stop building)
- project opcbrowsecontrol initialized by code : it works
01 Oct 2020 14:09 #8960 by support
is it the Visual Studio that is crashing - now when you mention opening the form designer? I was under impression it was the application itself, when ran in Debug mode.
There is no separate process for BoxedApp - it gets loaded into the same process as EasyXXClient component.
If it is VS crashing, can you try to make the same changes (kb.opclabs.com/How_to_disable_prerequisites_boxing ) to configuration file of VS itself? On my computer, it is "C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\Common7\IDE\devenv.exe.config" . Obviously this is a bit dangerous and the files is big out-of-the-box, so make a backup copy of it first.
A question: Have you been using multiple versions/builds of QuickOPC on this computer, or have you only ever installed one build of it on this computer?
30 Sep 2020 09:02 #8956 by PhilippeG
Windows 10 Version : 1709
I use the setting to disable boxApp but it doesn't work
EnableVC140RedistBoxer or EnableVC142RedistBoxer doesn't work
It works only if I do not open the form designer (contains EasyDAClient control)
How stop boxedapp? Is there any process
Best Regards
30 Sep 2020 07:50 #8955 by support
we have seen similar or same issue caused by incompatibility between recent Windows 10 version (2004) and the BoxedApp SDK ( a 3rd party library) we are using. However, build 5.58.257.1 is already updated to newer BoxedApp SDK, so I would expect to be OK in this respect. But there can be more issues.
Can you please
1. Tell me the full Windows 10 version (type WINVER into the Windows Search box).
2. Try this to see if it helps: kb.opclabs.com/How_to_disable_prerequisites_boxing
30 Sep 2020 07:05 #8954 by PhilippeG
Version QuickOPC :OPC Labs QuickOPC 2020.2
projects : see Attachments
File Name: testOp2c_2...9-30.zip
File Size:23 KB
Reference in the projects
OpcLabs.BaseLib.dll : 5.58.257.1
OpcLabs.EasyOpcClassic : 5.58.257.1
OpcComRcw : 2.0.105.1
Build with Visual Studio 2019
Framework 4.7.2
OS : Windows10
29 Sep 2020 17:19 #8953 by support
which version and build of QuickOPC are you using?
Time to create page: 0.074 seconds
