OPCUA read value issue
23 Sep 2021 13:54 #10226 by support
Replied by support on topic OPCUA read value issue
Also possibly related: github.com/OPCFoundation/UA-.NETStandard/issues/1509#issuecomment-925835871 (suggests a licensing issue?)
23 Sep 2021 08:54 #10225 by support
I am now using the precise same version of the TOP Server, and your configuration of the server. And, I cannot reproduce the issue. Here is the code I am running:
            EasyUAClient client = new EasyUAClient();
            var nodes = client.BrowseDataNodes("opc.tcp://localhost:49320", "nsu=TOP Server;s=TESTPLC1.TESTPLC1");
            foreach (var node in nodes)
                Console.WriteLine(node);
            Console.WriteLine();
            try
                object value = client.ReadValue("opc.tcp://localhost:49320", "nsu=TOP Server;ns=2;s=TESTPLC1.TESTPLC1.BodyStyle");
                Console.WriteLine(value);
            catch (UAException uaException)
                Console.WriteLine($"*** Failure: {uaException.GetBaseException().Message}");
            Console.ReadLine();
The program outputs the list of nodes. The ReadValue call then takes several seconds, and I get this error:
*** Failure: Status is not good: {Bad}.
I suppose this is the correct behavior, because I have no PLC connected. Notice that I do *not* get the BadNodeIdUnknown status.
Unfortunately, without a reproducible scenario it is difficult to help you further.
22 Sep 2021 13:27 #10224 by brandon.skiles@subaru-sia.com
The version is V6.6.348.0
30 Aug 2021 11:24 #10165 by support
Which version of the TOP Server are you using please? (in TOP Server Configuration program, do Help -> Support Information).
30 Aug 2021 09:56 #10164 by brandon.skiles@subaru-sia.com
Okay here is the Top Server config file.
27 Aug 2021 16:11 #10159 by support
thank you for the additional information. I understand it perfectly now. And, I do not see anything wrong in what you are doing (the space characters were probably due to some copy/paste issue in the first post).
So, in under to resolve this, I am really missing the TOP Server configuration. It should not be complicated to provide it; something like:
1. Start TOP Server Configuration program.
2. Choose File -> Save As from the menu.
3. If asked about encryption settings, select "No encryption..." (I am assuming you have nothing secret or confidential in the configuration), and press OK.
4. Select where the file (with .OPF extension) should be stored, press Save.
5. Attach the file to a new forum post here (it only has to be zipped if it is extremely big). OR, send it by email to support09 (at) opclabs.com.
Many thanks
27 Aug 2021 12:34 #10155 by brandon.skiles@subaru-sia.com
I dont believe that the spaces are the issue because when it works for the browse data nodes function and returns all of the nodes properly. I apologize that code was not clear. Here is a more clear version of the code. Also I am not sure how to save a zip of top server config however it seems to me that top server is not the issue as other programs are connected through OPC without a problem.
public void OPCRead()
            EasyUAClient easyUAClient = new EasyUAClient();
            var nodes = easyUAClient.BrowseDataNodes("opc.tcp://DevSSS.ccrtest.ccr:49380", "nsu=TOP Server;s=TESTPLC1.TESTPLC1");
I
The output of this is the following:
_System -> nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1._System (Object)
_Statistics -> nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1._Statistics (Object)
BodyStyle -> nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1.BodyStyle (Variable)
CarrierNumber -> nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1.CarrierNumber (Variable)
I then run the following code:
            easyUAClient.ReadValue("opc.tcp://DevSSS.ccrtest.ccr:49380", "nsu=TOP Server;ns=2;s=TESTPLC1.TESTPLC1.BodyStyle");
I get the following error:
OpcLabs.EasyOpc.UA.OperationModel.UAException: An OPC-UA operation failure with error ID 'Opc.UA.StatusCode=0x80340000' occurred, originating from '' and with depth of 1. The inner exception, of type "OpcLabs.EasyOpc.UA.UAStatusCodeException", contains details about the problem.
---> OpcLabs.EasyOpc.UA.UAStatusCodeException: Status is not good: {BadNodeIdUnknown}. The node id refers to a node that does not exist in the server address space.
+ The node descriptor used was: NodeId="nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1.BodyStyle".
+ The client method called (or event/callback invoked) was 'ReadMultiple'.
The QuickOPC version is 5.61.343
25 Aug 2021 19:25 #10148 by support
I see some weird usage of space characters (and its transformation to %20), maybe it is related to the issue.
For example, in "nsu =TOP Server;s=TESTPLC1.TESTPLC1", the space after "nsu" (and before "=") should not normally be there.
The other unusual thing is the space in the namespace ("TOP Server"); this is not normal because the namespace is a URI, and URIs cannot contain unescaped spaces either.
But, I cannot tell with certainty what is happening, I will need a reproducible scenario.
Can you please
1) Post here the TOP Server configuration (possibly zipped), and
2) Post here a full code that shows the problem (the parts you posted so far do not fit together - for example, I cannot tell how you obtained the tagName in the second snippet).
3) Indicate which QuickOPC version you are using
25 Aug 2021 18:23 #10146 by brandon.skiles@subaru-sia.com
I am having a problem trying to read a value from an OPC Server (TOP Server). I am sure that my endpoint descriptor that I am using is correct because it returns multiple nodes when I use EasyUAClient.BrowseDataNodes. When I run the follwing code:
            var nodes = easyUAClient.BrowseDataNodes("opc.tcp://DevSSS.ccrtest.ccr:49380", "nsu =TOP Server;s=TESTPLC1.TESTPLC1");
The output of this code:
ColorCode -> nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1.ColorCode (Variable)
D0004520 -> nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1.D0004520 (Variable)
I am then trying to read a value from one of the nodes that was found using the following code:
easyUAClient.ReadValue("opc.tcp://" + serverName, tagName);
+ The node descriptor used was: NodeId="nsu=TOP%20Server ;ns=2;s=TESTPLC1.TESTPLC1.CarrierNumber".
I do not understand this because I know the node I am trying to read exists
Time to create page: 0.080 seconds
