- Thank you received: 4
- Forum
- Discussions
- Feature Requests & Product Improvement Ideas
- Our .Net program crashes when the customer tries to browse for OPC servers or i
It looks that I was able to reproduce the issue. No further action is needed from you at this point. It will take some time to investigate; I will post here then.
Here is a link to our software.
spaces.hightail.com/receive/QvA1I1BpIk
My plan is now to install a new machine (VM in Azure) with Windows 10 version 2004, the OPC server, the appropriate QuickOPC version, and attempt to reproduce the issue.
If I fail to reproduce it with test programs of my own, I will also ask you for a copy of your software.
I will post here when I have an update.
See the download link below for Wonderware Intouch 2017 Update 3 SP1 P01:
u.pcloud.link/publink/show?code=XZSkOt7ZujpSfJ8I3BhYKyf7DlPvgbfB7FjV
Do you know how to obtain the server (trial)?
See the customer's answer below.
We installed this same UCME software in Server OS , Windows 10 with Version 1803 but it’s working fine for OPC Browser.
The OPC server is the part of Wonderware Intouch 2017 update 3 SP1 P01.
Thank you for your answer. I have asked the customer to provide us the exact Archestra version number. We shall download this version and test it in our office on the same Windows 10 version 2004.
I have hard time with error. It appears in a simple function that has no obvious bug, and has been working for almost 20 years without problem. I suspect WIndows 10 version 2004, because I have now some reports of weird things happening on *just* that version (reverting the Windows 10 version resolves the issues). But, I have Windows 10 version 2004 on a test computer as well, and could not reproduce the problem. So I would rather suspect something else peculiar about those machines.
I really need a reproducible scenario (i.e. probably figure out a combination of the software that triggers this); without it, it would be difficult to troubleshoot the problem. About my only choice would be to try to re-program the particular function (as there are different ways to do the required operations, so even if there is no bug but one way does not work, doing it differently may help). But that would be cumbersome and is is basically like shooting into the dark.
Faulting application name: UCMECFG.EXE, version: 2017.176.0.0, time stamp: 0x5f2ab1d9
Faulting module name: sxs.dll, version: 10.0.19041.1, time stamp: 0x8d364e65
Exception code: 0xc0000005
Fault offset: 0x0001d779
Faulting process id: 0x41a4
Faulting application start time: 0x01d66bd85429e748
Faulting application path: C:\Program Files (x86)\Control-See\UCME-OPC\BIN\UCMECFG.EXE
Faulting module path: C:\WINDOWS\SYSTEM32\sxs.dll
Report Id: d9816c9e-5ca9-4877-b2d4-dae494d182cd
Faulting package full name:
Faulting package-relative application ID:
Application: UCMECFG.EXE
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at <Module>.QueryMultipleInterfaces(IUnknown*, UInt32, tagMULTI_QI*)
at <Module>.VaryingQueryMultipleInterfaces(IUnknown*, UInt32, UInt32, CComSupport**, tagMULTI_QI*, CComSupport**)
at <Module>.COCKMachine.ConnectServerList(COCKMachine*)
at <Module>.COCKMachine.ExecuteConnect(COCKMachine*)
at <Module>.CMachine.Connect(CMachine*)
at <Module>.CConsumer.RequestMachine(CConsumer*, CMachineClient*, CMachine**, Boolean)
at <Module>.CClient.ConnectMyMachine(CClient*)
at <Module>.CClient.ExecuteConnect(CClient*)
at <Module>.COCKClientBase.ExecuteConnect(COCKClientBase*)
at <Module>.CAbstractClient.HandleConnectRequest(CAbstractClient*)
at <Module>.COCKClient.ReceiveAndProcessRequests(COCKClient*)
at <Module>.COCKClient.ExecuteWork(COCKClient*)
at <Module>.CAbstractClientWorkerThread.execute(CAbstractClientWorkerThread*)
at <Module>.CBasicWorkerThread.perform(CBasicWorkerThread*)
at <Module>.CBasicWorkerThread.process(CBasicWorkerThread*)
at <Module>.CBasicWorkerThread.threadProc(Void*)
Fault bucket 2223214427264078350, type 1
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: UCMECFG.EXE
P2: 2017.176.0.0
P3: 5f2ab1d9
P4: sxs.dll
P5: 10.0.19041.1
P6: 8d364e65
P7: c0000005
P8: 0001d779
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6F13.tmp.mdmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6FEF.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6FFF.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6FFD.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER701E.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_UCMECFG.EXE_d3d6c85faf5db76064ab37951617db2b476f832c_fe0b963a_dfefd2b8-3bb0-41d0-bcda-c35af10e7057
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: 60c54533eb779fc3beda71be1499520e
Cab Guid: 0
- Forum
- Discussions
