how can i read a variable from type DTL in my program to C#
17 Jan 2020 11:59 #8149 by support
you should use the ReadMultipleMethods (example: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...0Read%20multiple%20values.html ).
That is not going to simplify the code that much, but it will be much more efficient.
If the structure is also provided as an OPC UA Data Type (which is a *different* thing from a variable type), then it might be possible to read the whole structure at once. But I cannot know whether that is the case on the server side. In that case you would simply read the array element, and get back an object containing the structure membets. This is described here:
- www.opclabs.com/products/quickopc/extensions/opc-ua-complex-data
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...omplex%20Data%20Extension.html .
The following user(s) said Thank You: alozano
17 Jan 2020 11:26 #8146 by alozano
now I am using this method to read a variable of type DTL and I will like it simplify the code, anyone can help me?
Time to create page: 0.043 seconds
