- Forum
- Discussions
- Feature Requests & Product Improvement Ideas
- Application using OPC Labs Easy UA Client is throwing a unhandled exception
29 Aug 2018 14:30 #6623
by support
Replied by support on topic Application using OPC Labs Easy UA Client is throwing a unhandled exception
can you show a piece of code that does the exception handling on calls to QuickOPC, or in the event handler? There are legitimate exceptions that can be thrown and cannot be fully prevented - for example, when the communication with the target OPC server breaks for any reason (server down, network problem etc.). This may be your case as well. The program needs to be written so that it handles these errors/exceptions properyl, and we have instructions for that - see e.g. opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...frame.html#Best_Practices.html .
- alex.garnier@radixinc.ca
- Topic Author
- Offline
- New Member
Less
- Thank you received: 0
29 Aug 2018 12:22 #6621
by alex.garnier@radixinc.ca
Application using OPC Labs Easy UA Client is throwing a unhandled exception was created by alex.garnier@radixinc.ca
OpcLabs.EasyOpc.UA.Engine.UAClientEngineException: Cannot lock the OPC-UA client session because it is not available.
This error shows up once in a blue moon and crashes the entire program. I can't recreate it and my debugging options are highly limited on a deployed machine. Its installed on a machine running production on a assembly line. What causes this error and how can I program around it? I can't find any details online.
Software/computer details:
* Running as a C# class library embedded into a cognex designer project.
* 64 bit windows embedded standard
Full error message:
Full error message:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2558.0 built by: NET471REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Cognex.Designer
Assembly Version: 1.0.0.0
Win32 Version: 2.7.0.6451
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.exe
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Cognex.Designer.Core
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Core.DLL
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.2558.0 built by: NET471REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
NLog
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/NLog.DLL
Cognex.Designer.Utils
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Utils.DLL
Cognex.Designer.Plugin
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Plugin.DLL
Cognex.Designer.UI.Utils
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.UI.Utils.DLL
Cognex.Designer.Serialization.Json
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Serialization.Json.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Windows.Forms
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.ServiceModel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Cognex.Designer.Implementation
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Implementation.DLL
Newtonsoft.Json
Assembly Version: 6.0.0.0
Win32 Version: 6.0.4.17603
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Newtonsoft.Json.DLL
Ionic.Zip
Assembly Version: 1.9.1.8
Win32 Version: 1.9.1.8
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Ionic.Zip.DLL
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Cognex.Designer.Database
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Database.DLL
System.Data.SQLite
Assembly Version: 1.0.93.0
Win32 Version: 1.0.93.0
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.ComponentModel.DataAnnotations
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Cognex.VisionPro.Core
Assembly Version: 63.0.0.0
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.Core/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Core.dll
SMDiagnostics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
Cognex.Designer.Plugin.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Plugin.IDE.DLL
Cognex.Designer.Alarms
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Alarms.DLL
Cognex.Designer.Alarms.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Alarms.IDE.DLL
Cognex.Designer.AuditTrail
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.AuditTrail.DLL
Cognex.Designer.AuditTrail.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.AuditTrail.IDE.DLL
Cognex.Designer.Authentication
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Authentication.DLL
Cognex.Designer.Authentication.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Authentication.IDE.DLL
Cognex.Designer.Components
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Components.DLL
Cognex.Designer.Components.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Components.IDE.DLL
Cognex.Designer.Database.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Database.IDE.DLL
Cognex.Designer.Devices
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Devices.DLL
Cognex.Designer.Devices.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Devices.IDE.DLL
Cognex.Designer.Devices.IO
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Devices.IO.DLL
Cognex.Designer.Devices.IO.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Devices.IO.IDE.DLL
Cognex.Designer.Devices.Rs232
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Devices.Rs232.DLL
Cognex.Designer.Devices.TCPIP
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Devices.TCPIP.DLL
Cognex.Designer.HMI.Controls
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.HMI.Controls.DLL
Cognex.Designer.HMI
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.HMI.DLL
Cognex.Designer.HMI.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.HMI.IDE.DLL
Cognex.Designer.IDE.Controls
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.IDE.Controls.DLL
Cognex.Designer.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.IDE.DLL
Cognex.Designer.IDE.Explorer
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.IDE.Explorer.DLL
Cognex.Designer.Recipes
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Recipes.DLL
Cognex.Designer.Recipes.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Recipes.IDE.DLL
Cognex.Designer.Resources
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Resources.DLL
Cognex.Designer.Resources.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Resources.IDE.DLL
Cognex.Designer.Scripting.CSharp
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Scripting.CSharp.DLL
Cognex.Designer.Scripting.CSharp.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Scripting.CSharp.IDE.DLL
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Scripting.DLL
Cognex.Designer.Scripting.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Scripting.IDE.DLL
Cognex.Designer.Sequences
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Sequences.DLL
Cognex.Designer.Sequences.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Sequences.IDE.DLL
Cognex.Designer.Templates.IDE
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Templates.IDE.DLL
Cognex.Designer.Windows
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Windows.DLL
Cognex.Designer.VisionPro.CommCard
Win32 Version: 2.7.0.936
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/Cognex/VisionPro/2.3.0/Any/Cognex.Designer.VisionPro.CommCard.dll
Cognex.Designer.VisionPro.Controls
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/Cognex/VisionPro/2.3.0/Any/Cognex.Designer.VisionPro.Controls.dll
Cognex.Designer.VisionPro.Controls.Extended
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/Cognex/VisionPro/2.3.0/Any/Cognex.Designer.VisionPro.Controls.Extended.dll
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/Cognex/VisionPro/2.3.0/Any/Cognex.Designer.VisionPro.dll
Cognex.Designer.VisionPro.IDE
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/Cognex/VisionPro/2.3.0/Any/Cognex.Designer.VisionPro.IDE.dll
AForge
Assembly Version: 2.2.5.0
Win32 Version: 2.2.5.0
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/AForge.dll
AForge.Imaging
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/AForge.Imaging.dll
AForge.Math
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/AForge.Math.dll
AsyncIO
Assembly Version: 0.1.20.0
Win32 Version: 0.1.20.0
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/AsyncIO.dll
NetMQ
Assembly Version: 3.3.3.4
Win32 Version: 3.3.3.4
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/NetMQ.dll
ViDi.NET.Base
Assembly Version: 2.1.0.3676
Win32 Version: 2.1.0.3676
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/ViDi.NET.Base.dll
ViDi.NET
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/ViDi.NET.dll
ViDi.NET.Interfaces
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/ViDi.NET.Interfaces.dll
ViDi.NET.Local
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/ViDi.NET.Local.dll
ViDi.NET.Remote
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/ViDi.NET.Remote.dll
ViDi.NET.UI
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/ViDi.NET.UI.dll
ViDi.NET.UI.Interfaces
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/ViDi.NET.UI.Interfaces.dll
WibuCmNET
Assembly Version: 5.22.168.500
Win32 Version: 5.22.168.500
CodeBase: file:///C:/Runtime/PTWA%20Post%20Spray/Plugins/ViDi/ViDi%20Suite%202.1/2.1.0/x64/WibuCmNET.dll
Mono.Cecil
Assembly Version: 0.9.5.0
Win32 Version: 0.9.5.0
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Mono.Cecil.DLL
Cognex.VisionPro.Comm
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.Comm/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Comm.dll
Cognex.VisionPro
Win32 Version: 63.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.dll
Cognex.Designer.Imaging
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Cognex.Designer.Imaging.DLL
protobuf-net
Assembly Version: 2.0.0.664
Win32 Version: 2.0.0.664
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/protobuf-net.DLL
ICSharpCode.NRefactory
Assembly Version: 5.0.0.0
Win32 Version: 5.5.1
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/ICSharpCode.NRefactory.DLL
Cognex.VisionPro.Controls
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.Controls/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Controls.dll
Cognex.VisionPro.Display.Controls
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.Display.Controls/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Display.Controls.dll
Cognex.VisionPro.ToolGroup.Controls
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.ToolGroup.Controls/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.ToolGroup.Controls.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PTWA-Library
Assembly Version: 1.0.6668.19139
Win32 Version: 1.0.6668.19139
CodeBase: file:///C:/RADIX/Library/PTWA-Library.dll
CognexDesignerInterface
Win32 Version: 1.0.0.0
CodeBase: file:///C:/RADIX/Library/CognexDesignerInterface.dll
Core
Assembly Version: 1.0.6795.15393
Win32 Version: 1.0.6795.15393
CodeBase: file:///C:/RADIX/Library/Core.dll
OPC.Communication
CodeBase: file:///C:/RADIX/Library/OPC.Communication.dll
ICSharpCode.NRefactory.CSharp
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/ICSharpCode.NRefactory.CSharp.DLL
Cognex.VisionPro.Blob
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.Blob/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Blob.dll
Cognex.VisionPro.FGGigE
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.FGGigE/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.FGGigE.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.ToolGroup/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.ToolGroup.dll
Cognex.VisionPro.ID
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.ID/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.ID.dll
Cognex.VisionPro.QuickBuild.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.QuickBuild.Core/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.QuickBuild.Core.dll
Cognex.VisionPro.ImageFile
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.ImageFile/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.ImageFile.dll
Cognex.VisionPro.ImageProcessing
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.ImageProcessing/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.ImageProcessing.dll
1yw4d1o3
Assembly Version: 0.0.0.0
Cognex.VisionPro.PixelMap
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.PixelMap/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.PixelMap.dll
Cognex.VisionPro.CalibFix
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.CalibFix/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.CalibFix.dll
rq1dxkgx
we3t4o21
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Cognex.VisionPro.Interop.Core
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Cognex.VisionPro.Interop.Core/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Interop.Core.dll
Cognex.VisionPro.Interop.DisplayCtl
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Cognex.VisionPro.Interop.DisplayCtl/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Interop.DisplayCtl.dll
Xceed.Wpf.Toolkit
Assembly Version: 2.1.0.0
Win32 Version: 2.1.0.0
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/Xceed.Wpf.Toolkit.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
Microsoft.GeneratedCode
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
System.Reactive.PlatformServices
Assembly Version: 2.0.20823.0
Win32 Version: 2.0.21103.1
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/System.Reactive.PlatformServices.DLL
System.Reactive.Core
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/System.Reactive.Core.DLL
System.Reactive.Interfaces
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/System.Reactive.Interfaces.DLL
System.Reactive.Linq
CodeBase: file:///C:/Program%20Files/Cognex/Designer/2.7/System.Reactive.Linq.DLL
Cognex.Designer.Scripting.GeneratedScripts._74fdaed2f1e54b42b03392c8b71103fd
Assembly Version: 1.0.6801.21451
CodeBase: file:///C:/Users/dynics/AppData/Local/Temp/Cognex.Designer.Scripting.GeneratedScripts._74fdaed2f1e54b42b03392c8b71103fd/bin/Cognex.Designer.Scripting.GeneratedScripts._74fdaed2f1e54b42b03392c8b71103fd.dll
System.Runtime.Serialization.Formatters.Soap
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
OpcLabs.EasyOpcUA
Assembly Version: 5.52.91.1
Win32 Version: 5.52.91.1
CodeBase: file:///C:/RADIX/Library/OpcLabs.EasyOpcUA.DLL
OpcLabs.BaseLib
CodeBase: file:///C:/RADIX/Library/OpcLabs.BaseLib.DLL
log4net
Assembly Version: 2.0.8.0
Win32 Version: 2.0.8.0
CodeBase: file:///C:/RADIX/Library/log4net.DLL
Opc.Ua.Client
Assembly Version: 1.3.342.0
CodeBase: file:///C:/RADIX/Library/OpcLabs.BaseLib.dll
Opc.Ua.Core
Opc.Ua.Configuration
OpcLabs.BaseLibForms
CodeBase: file:///C:/RADIX/Library/OpcLabs.BaseLibForms.DLL
System.ServiceModel.Internals
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
BoxedAppSDK.Managed
Assembly Version: 3.3.14.0
System.IdentityModel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
QLSCMAPIDLLCS
Assembly Version: 2.2.0.0
Win32 Version: 2.2.0.0
CodeBase: file:///C:/RADIX/Library/QLSCMAPIDLLCS.DLL
System.IO.Compression.FileSystem
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Web.Services
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Cognex.VisionPro.CorePlus
Win32 Version:
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.CorePlus/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.CorePlus.dll
Cognex.VisionPro.Inspection
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.Inspection/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Inspection.dll
Cognex.VisionPro.Inspection.Controls
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.Inspection.Controls/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.Inspection.Controls.dll
Cognex.VisionPro3D.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro3D.Core/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro3D.Core.dll
j05go2yk
sd22saku
omur12ti
mrfmaxt2
Cognex.VisionPro.ImageProcessing.Controls
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.ImageProcessing.Controls/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.ImageProcessing.Controls.dll
Cognex.VisionPro.ID.Controls
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/Cognex.VisionPro.ID.Controls/v4.0_63.0.0.0__ef0f902af9dee505/Cognex.VisionPro.ID.Controls.dll
PresentationFramework-SystemData
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
- Forum
- Discussions
Time to create page: 0.387 seconds
