Exception on Write Boolean Value
04 Jul 2018 18:08 #6495 by support
I apologize, the actual name of the attribute is ValueRank, not ArrayRank.
You do not need to create it, the server already has this attribute on each variable node. If you are using UAExpert, it should be able to show its value to you. What is its value?
The reason I am asking about it is that it could be a server bug. It can be reporting itself as an array, while being a scalar in reality. That's why I need to know the value of ValueRank.
04 Jul 2018 07:37 #6492 by Scattolaro
Ok, but if when I read the same node the OPClabs library return me a Boolean.
How is it possible that when I try to write the same node it's necessary to send an array? How do I do create this ArrayRank that you talk about?
I don't understand.
04 Jul 2018 07:30 #6489 by support
It looks like that QuickOPC is trying to convert the value you provided (a Boolean) to an array. This must be for a reason. Most likely, the ArrayRank attribute of the node contains value that indicates that the node is an array. Check that. What is the rank value?
03 Jul 2018 09:46 #6485 by Scattolaro
When I try to write a value(Type boolean) that I read properly the OPC labs library return me this Exception below:
Exception: OpcLabs.EasyOpc.UA.OperationModel.UAException: An OPC-UA operation failure with error code -1 (0xFFFFFFFF) occurred, originating from 'mscorlib'. The inner exception, of type 'System.InvalidCastException', contains details about the problem. ---> System.InvalidCastException: Cast da 'System.Boolean' a 'System.Object[]' non valido. in System.Convert.DefaultToType(IConvertible value, Type targetType, IFormatProvider provider) in System.Boolean.System.IConvertible.ToType(Type type, IFormatProvider provider) in System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider) in OpcLabs.BaseLib.Utilities.ConvertUtilities.EnrichedChangeType(Object value, Type conversionType, IFormatProvider provider) in OpcLabs.BaseLib.Utilities.ConvertUtilities.CheckedChangeType(Object value, Type conversionType, IFormatProvider provider) in OpcLabs.BaseLib.Utilities.ObjectUtilities.ChangeType(Object value, Type type, Object& result) --- Fine della traccia dello stack dell'eccezione interna --- in OpcLabs.EasyOpc.UA.EasyUAClient.CheckSuccess(OperationResult operationResult) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAWriteValueArguments writeValueArguments) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, Object value, Type valueType) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, Object value) in Qualitas.DeviceAppOPC.DataAccess.OPCserverCH.Write(String nName, Object value)(An OPC-UA operation failure with error code -1 (0xFFFFFFFF) occurred, originating from 'mscorlib'. The inner exception, of type 'System.InvalidCastException', contains details about the problem.) Trace: in OpcLabs.EasyOpc.UA.EasyUAClient.CheckSuccess(OperationResult operationResult) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAWriteValueArguments writeValueArguments) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, Object value, Type valueType) in OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, Object value) in Qualitas.DeviceAppOPC.DataAccess.OPCserverCH.Write(String nName, Object value);
My OPC labs library version is (OpcLabs.EasyOpcUA.dll version:5.52.147.1).
So I attach 2 screenshot of UAExpert that work properly(on read and write) but the OPCLabs library don't work on write.
Can you help me please? Where is it the error?
