OPC UA Web App Unable to Recognize License
22 Mar 2021 16:18 #9534 by support
G.,
thank you, this is helpful. May do the "license key in file system" licensing for 2021.2 or 2021.3.
The following user(s) said Thank You: gkalipershad
22 Mar 2021 14:35 #9530 by gkalipershad
Z,
1) There is some value to this. I would say that users who target .NET Core are more likely to be deploying to Linux and MacOS (once this becomes more widely known and adopted), so the few that are targeting .NET Core and deploying to Windows, would probably be fine embedding the license as a managed resource as we have had this user do. Considering the limited group that this would affect, I think this could add value, but would maybe be considered to be a low priority feature addition. You may see this use-case more often on your end, which would of course change things.
2) With a majority of the users I encounter using WinForms, I see a lot of value in doing this. Our team as a whole often receives inquiries about licensing deployment (about 3 inquiries on average per month on deployment methods), so if that process can be simplified, it would be helpful. As long as you are okay with the concern you mentioned, this is definitely something I see value in considering.
GK
22 Mar 2021 13:26 #9529 by support
Great, thanks for update.
Looking for some opinion on related issues here:
1) Would you see a value in allowing registry-based licenses also under .NET Core? (but still, on Windows only - as there is no registry on Linux or macOS) ?
2) Would you see a value in allowing the product be licensed simply by placing the license key file alongside the executable? (note that it may not be the ideal or doable way for the particular IIS scenario, as the executable is the IIS itself). Downside would be that license keys would be easier copyable (but we never intended to really prevent their copying; and they would still not be modifiable).
22 Mar 2021 13:18 #9528 by gkalipershad
Z,
The customer confirmed for me that there are no licensing exceptions after embedding the license file as a managed resource and deploying to IIS.
Thanks for setting me straight on this!
GK
17 Mar 2021 20:06 #9516 by gkalipershad
Ahhh I see. I had a feeling I was missing something simple. This is a result of not having to support .NET Core users very often. I appreciate your answer and I will confirm whether the customer is successful in this implementation.
GK
17 Mar 2021 19:54 #9515 by support
If they compile for .NET Core, the license isn't read from the registry at all: softwaretoolbox.doc-that.com/files/onlinedocs/OpcDataClient/.../webframe.html#Licensing3.html
They need to embed it in the managed resources (softwaretoolbox.doc-that.com/files/onlinedocs/OpcDataClient/...esource%20License%20Store.html ) .
This hasn't been tested under IIS, though, but should work.
17 Mar 2021 19:01 #9514 by gkalipershad
I have been working with a customer that has an OPC Data Client Professional Edition license.
The are using the following:
- OPC Data Client 2020.3 (5.59.492.1)
- Windows Server 2019 Datacenter Version 1809
- .NET Core 3.1.0
Whenever they run their Web App that is hosted on IIS, they get the following error after 30 minutes:
"Run time is over the limit in license "Multipurpose", serial number 1111111120. The license you are running (most likely trial version) does not provide valid data after certain time period expires. Note that after the component's process is simply restarted, valid data will be provided again. Obtain and install proper license to permanently resolve this error. Product information follows. Component name: "QuickOPC", license IDs: "Multipurpose", version number: 559, release date: 12/3/2020, trial validity: 397 days, option expression: "EasyUAClient". Context: 0 dropped license(s). + The client method called was 'DataChangeNotification'."
Here are some things I have already looked for:
- This does happen on both the development machine and when deployed to IIS.
- The license was applied through the License Manager and not through any other methods.
- The correct 'QuickOpc' component was licensed.
- The Release date covered is 2/9/2022, so all good there.
- The EasyOpcUADemo runs fine and does not encounter license error after 30min.
I had believed this issue was related to the "Access to the License" section here: softwaretoolbox.doc-that.com/files/onlinedocs/OpcDataClient/...bframe.html#License_Store.html
We had them show us what user the Application Pool was running under and then we had them go into the registry and confirm that the user account had read access to HKEY_LOCAL_MACHINE\SOFTWARE\Licensing\QuickOPC\Multipurpose.
I'm afraid that after all that, I am out of ideas. Hoping you could provide some input that might get us going in the right direction.
GK
