Version differences
05 May 2020 13:46 #8468 by support
Replied by support on topic Version differences
this problem is now fixed, thank you for reporting it. There was a wrong dependency version number in .nuspec for the QuickOpc package.
Please rebuild with 5.58.192 or later - both the installer download and NuGet package are now synchronized.
The following user(s) said Thank You: ted
05 May 2020 05:01 #8463 by support
packages for build 5.58.184.1 should have been uploaded to NuGet, that's an omission on our side.
I can upload them but first I will look into the "other" issue - because if it requires fix & another build, there would be no point in uploading 5.58.184.1.
I will reply here when I know more.
04 May 2020 17:02 #8460 by ted
Version differences was created by ted
Trying to evaluate QuickOpc on Windows / Net Core 3.1.201 / Rider 2020.1
I ran the QuickOpc installer and unpacked the examples fetched from
opclabs.doc-that.com/files/onlinedocs/QuickOpc/2020.2/User%2...NET%20Standard%20Examples.html
"C# examples for .NET Core". This is the build output: (see below)
The problem seems to be that the project expects version 5.58.184, but Nuget only has 5.58.151.
After downgrading to 5.58.151 I can run both "MultiTargetDocExamples" and "MultiTargetUADocExamples"
However, the last one, after choosing point 1 (Main), then point 1 (UADocExamples._EasyUAClient.BrowseDataNodes.Overload1"), it crashes with this error:
Unhandled Exception: System.IO.FileLoadException: Could not load file or assembly 'Opc.Ua.Core, Version=1.4.360.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8'. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT:
 0x80131040)
Where should this dll be installed from?
Goal is to the the communication going using the OPC-UA Demo Publisher 5.58.184.1
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\DocExamples\MultiTargetDocExamples.csproj : error NU1102: Unable to find package OpcLabs.QuickOpc with version (>= 5.58.184) [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\DocExamples\MultiTargetDocExamples.csproj : error NU1102:   - Found 73 version(s) in nuget.org [ Nearest version: 5.58.151 ] [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\DocExamples\MultiTargetDocExamples.csproj : error NU1102:   - Found 0 version(s) in Gith [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102: Unable to find package OpcLabs.MqttNet with version (>= 5.58.184) [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102:   - Found 8 version(s) in nuget.org [ Nearest version: 5.58.151 ] [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102:   - Found 0 version(s) in Gith [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102: Unable to find package OpcLabs.Pcap with version (>= 5.58.184) [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102:   - Found 7 version(s) in nuget.org [ Nearest version: 5.58.151 ] [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102: Unable to find package OpcLabs.UAPubSubJson with version (>= 5.58.184) [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102: Unable to find package OpcLabs.QuickOpc with version (>= 5.58.184) [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
C:\t\DS\sw\tests\csharp\Test.Opclabs\Console\UADocExamples\MultiTargetUADocExamples.csproj : error NU1102:   - Found 73 version(s) in nuget.org [ Nearest version: 5.58.151 ] [C:\t\DS\sw\tests\csharp\Test.Opclabs\QuickOpcCSharpMultiTargetExamples.sln]
Time to create page: 0.091 seconds
