- Forum
- Discussions
- QuickOPC-Classic in .NET
- Connections, Reconnections, COM/DCOM
- DeltaV browsing issue
23 Jan 2018 14:25 #5899
by support
Replied by support on topic DeltaV browsing issue
You wrote "still struggling" - have we communicated about this issue before? If so, can you please point to a topic on the forums, or email (date)? Thank you very much.
Some questions:
1. Does it happen only with browsing, or with other OPC operations too?
2. Does it happen always, often, sometimes, rarely?
3. What about other OPC clients - can they browse?
4. Does your client run in 32-bit or 64-bit process?
5. Is the client on the same machine as the server, or is it via DCOM - remotely?
Some questions:
23 Jan 2018 14:22 #5898
by support
DeltaV browsing issue was created by support
Sent: Tuesday, January 23, 2018 10:54 AM
To: Z.
Subject: DeltaV browsing issue
Hi Z.,
We are still struggling with the Browsing issue using the DeltaV OPC server. Please see below the Inner Exception details.
Do you know what may cause this problem?
To: Z.
Hi Z.,
Exceptions
OpcLabs.EasyOpc.OperationModel.OpcException: An OPC operation failure with error code -2147221164 (0x80040154) occurred, originating from 'OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient'. The inner exception contains details about the problem. ---> System.Runtime.InteropServices.COMException: Class not registered
at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.CheckOpcResult(CHResult* hResult)
at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.InternalBrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.Internal.ForwardingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.Internal.PSBoxingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.Internal.EasyDAClientCompositor.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.Internal.CompositeEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.Internal.LicensingEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.EasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.Browsing.DANodeBrowseable.BrowseBranches(Object parentNode, Object nodeFilter, IEnumerable`1& branches, IEnumerable`1& exceptions)
ErrorCode: -2147221164
InnerException: System.Runtime.InteropServices.COMException (0x80040154): Class not registered
HResult: -2147221164 (0x80040154)
Message: Class not registered
Source: OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient
TargetSite:
Message: An OPC operation failure with error code -2147221164 (0x80040154) occurred, originating from 'OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient'. The inner exception contains details about the problem.
Source: App_Web_OpcLabs.EasyOpcClassicRaw.amd64
TargetSite: Void CheckOpcResult(CHResult*)
DeclaringType: OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient
Module: App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll
Assembly: App_Web_OpcLabs.EasyOpcClassicRaw.amd64, Version=5.41.1253.1, Culture=neutral, PublicKeyToken=6faddca41dacb409
CustomAttributes:
FullyQualifiedName: C:\Program Files (x86)\Control-See\UCME-OPC\BIN\App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: 0c1165e8-dbca-41c8-b1c4-bf9845e2ed07
ScopeName: App_Web_OpcLabs.EasyOpcClassicRaw.amd64.dll
Message: Problem browsing OPC Data Access (OPC-DA) branches.
Source:
TargetSite:
- Forum
- Discussions
