Different QuickOPC runtime revisions on the same PC
28 Jun 2021 13:00 #9833 by lamar
(A) Win7 + Delphi 10.2 Rio + QuickOPC 2019.1
(B) Win10 + Delphi 10.4 Sydney + QuickOPC 2019.1
(C) Win10 + Delphi 10.4 Sydney + QuickOPC 2021.2
My app reads a random value generating tag in every second.
( Matrikon.OPC.Simulation.1 /// Random.UInt1 )
I tested the behaviour in a separate Win10 environment with Matrikon OPC Simulation Server.
When I install 2019.1 runtime only
(A) runs OK
(B) runs OK
(C) gives Access Violation error (this is behaviour is OK)
When I install 2019.1 and 2021.2 runtime
(A) does not start, no errors, no warnings, simply does nothing
(B) does not start, no errors, no warnings, simply does nothing
(C) does not start, no errors, no warnings, simply does nothing
When I install 2021.2 runtime only
28 Jun 2021 11:21 #9828 by support
are you using QuickOPC from .NET, or from some COM tool (VB6, Delphi, ...)?
Also, please describe symptoms of "the application ... stops to work.".
28 Jun 2021 10:37 #9826 by lamar
it seems that if I install two different runtime revisions,
the application that is compiled for the older revision
stops to work. However if I install only the newer runtime,
the compilations for the older revision also fail. Is that normal?
It is essential for us to use different runtime revisions as
besides our application we use two other third party software
that has QuickOPC resources inside.
