HELP OPC PHP IN IIS 7
05 Jan 2014 02:49 #1651 by gsa_systems
Replied by gsa_systems on topic HELP OPC PHP IN IIS 7
thanks very much.. :D
i suppose is my PHP installation that is wrong, i´ll to reinstall all whit another version of php more current.
really thanks for your time and try to help me.
when I've a result I'll post.
04 Jan 2014 16:47 #1650 by support
Replied by support on topic HELP OPC PHP IN IIS 7
If the error still says "Class 'COM' not found", it is likely that the problem is not related specifically to the EasyDAClient component. It is the 'COM' class, that is a wrapper for COM objects, which is not found - not the EasyDAClient.
You therefore need to resolve this with your PHP installation. We are not PHP experts here, and I am afraid we cannot help further at this point.
The following user(s) said Thank You: gsa_systems
03 Jan 2014 21:09 #1649 by gsa_systems
i´ve downloaded .dll and made all steps. but i have the same yet..
03 Jan 2014 19:53 #1648 by support
Aren't you missing this:
[COM_DOT_NET]
 extension=php_com_dotnet.dll
see
stackoverflow.com/questions/10678325/class-com-not-found
www.php.net/manual/en/com.installation.php
03 Jan 2014 19:47 - 03 Jan 2014 19:49 #1647 by gsa_systems
i've commented out the line of ReadItemValue, the error show yet.. i suppose the problem is in the line "$EasyDAClient= new COM("OPCLabs.EasyDAClient.5.2");" because the error say "lass 'COM' not found"
thanks for help me so fast :D
... mmm i'm thinking if the problem could be the server IIS 7
Last edit: 03 Jan 2014 19:49 by gsa_systems.
03 Jan 2014 19:22 #1646 by support
If you remove (or comment out) the second statement, i.e. the whole assignment from the ReadItemValue method call, does it still show the same error?
I am trying to determine whether the problem is in the EasyDAClient client instantiation (the first statement), or the OPC read (the second statement).
03 Jan 2014 18:25 - 03 Jan 2014 19:00 #1645 by gsa_systems
Hellow everyboy... i hope can help me..
i´m using windows server with IIS7, php its configurated correctly i suppose..
when use a DEMO APLICATION (com) i can read data. but when i try to use the example to read in php, te page show an error... at first show FATAL ERROR 500.
i have one week to resolve this problem !!!
add an image to see the problem.
error to see the page
Last edit: 03 Jan 2014 19:00 by gsa_systems.
