- Thank you received: 4
- Forum
- Discussions
- QuickOPC-Classic in .NET
- Browsing, Browse Dialogs and Controls
- My program is crashing when browsing Matrikon OPC Tunneller (UA to DA)
We have downloaded the latest version and created a new version of our product.
WE shall test it and let you know the results.
This should be now fixed, in QuickOPC 5.62.1032.1 or later (hopefully: We could not reproduce it, but we could understand the cause of the problem in the code, and have simulated it internally).
Please download the recent version from our Web site, rebuild & retest.
yes, this is clearly our problem, thanks for reporting it. I will forward it to the developer and let you know when we have an update.
Best regards.
I am using Quick OPC Client version 2021.3 (5.62.503.1).
When I am doing DA browsing while connected to Matrikon OPC Tunneller (connected to Prosys OPC UA server), my program crashes. See the Event Logger information below.
Source .NET Runtime
Application: UCMECFG.EXE
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArgumentOutOfRangeException
at System.DateTime.AddTicks(Int64)
at OpcCom.Interop.GetFILETIME(System.Runtime.InteropServices.ComTypes.FILETIME)
at OpcCom.Da.Interop.GetServerStatus(IntPtr ByRef, Boolean)
at OpcCom.Da.Server.GetStatus()
at Opc.Da.Server.GetStatus()
at OpcLabs.EasyOpc.Implementation.NetApi.DataAccess.NetApiOpcDaServer.GetStatusInternal(Opc.Da.Server)
at OpcLabs.EasyOpc.Implementation.NetApi.NetApiOpcServer`2[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].GetStatus(Boolean, System.Exception ByRef)
Exception Info: System.InvalidOperationException
Server stack trace:
at OpcLabs.EasyOpc.Implementation.NetApi.INetApiEasyClientExtension.CheckException(INetApiEasyClient netApiEasyClient, Exception exception, Boolean isOtherMethod)
at OpcLabs.EasyOpc.Implementation.NetApi.DataAccess.NetApiEasyToOpcNetApiDa.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.Implementation.NetApi.DataAccess.NetApiEasyDAClient.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.TimeoutImposingEasyDAClient.<>c__DisplayClass6_0.<BrowseNodes>b__0()
at OpcLabs.EasyOpc.DataAccess.Implementation.TimeoutImposingEasyDAClient.<>c__DisplayClass13_0`1.<ImposeTimeout>b__0()
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
at System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(System.Runtime.Remoting.Messaging.Message, Boolean)
at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(System.Object, System.Runtime.Remoting.Proxies.MessageData ByRef)
at System.Action.EndInvoke(System.IAsyncResult)
at OpcLabs.BaseLib.Threading.InvokeParallelism.Wait(System.IAsyncResult)
at OpcLabs.BaseLib.Extensions.Internal.ActionExtension.Perform(System.Action, Int32)
at OpcLabs.BaseLib.Extensions.Internal.ActionExtension.Perform(System.Action, Int32, Boolean)
at OpcLabs.EasyOpc.DataAccess.Implementation.TimeoutImposingEasyDAClient.ImposeTimeout[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Func`1<System.__Canon>, Int32)
at OpcLabs.EasyOpc.DataAccess.Implementation.TimeoutImposingEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.PSBoxingEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.DelegatingEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.ErrorTransformingEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.BrowsePathResolvingEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.EasyDAClientCompositor.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.CompositeEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.ForwardingEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Implementation.LicensingEasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.EasyDAClient.BrowseNodes(OpcLabs.EasyOpc.ServerDescriptor, OpcLabs.EasyOpc.DataAccess.DANodeDescriptor, OpcLabs.EasyOpc.DataAccess.DABrowseParameters)
at OpcLabs.EasyOpc.DataAccess.Browsing.DANodeBrowseable.BrowseLeaves(System.Object, System.Object, System.Collections.Generic.IEnumerable`1<System.Object> ByRef, System.Collections.Generic.IEnumerable`1<System.Exception> ByRef)
at OpcLabs.BaseLib.Forms.Browsing.Parts.ConditionalBrowseable.BrowseLeaves(System.Object, System.Object, System.Collections.Generic.IEnumerable`1<System.Object> ByRef, System.Collections.Generic.IEnumerable`1<System.Exception> ByRef)
at OpcLabs.BaseLib.Forms.Browsing.Parts.BrowseNodesControl.BrowseChildrenJob0(System.Object)
at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart(System.Object)
Source: Application error
Faulting application name: UCMECFG.EXE, version: 2020.401.0.0, time stamp: 0x61defa91
Faulting module name: KERNELBASE.dll, version: 10.0.16299.611, time stamp: 0x966d0f68
Exception code: 0xe0434352
Fault offset: 0x00104172
Faulting process id: 0x7584
Faulting application start time: 0x01d807d3972bd750
Faulting application path: C:\Program Files (x86)\Control-See\UCME-OPC\BIN\UCMECFG.EXE
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: fd3f5244-1d13-4272-8be0-c257e5f30b41
Faulting package full name:
Faulting package-relative application ID:
Can you please assist?
- Forum
- Discussions
