Should we include the Opc.Ua.CertificateGenerator.exe file in our setup?
09 Jul 2021 07:12 #9966 by support
The answer is: Normally no, you should not include it. In fact, doing so may cause problems, because if a wrong version is incldued, QuickOPC may fail.
There are situations under which including the certificate generator EXE may be needed - this usually is when there is a problem with the "boxing" library, and the librarye needs to be turned off - as described on kb.opclabs.com/How_to_disable_prerequisites_boxing . But this is not your/the customer case (at least we have not determined that).
I will reply to your other post with the certificate generator-related error later, separately.
08 Jul 2021 17:51 #9965 by micham
Should we include the Opc.Ua.CertificateGenerator.exe file in the same folder where our EXE file is? If yes, should we include other file that can be found in
C:\Program Files (x86)\OPC Labs QuickOPC 2021.1\Bonus\Opc.Ua.ConfigurationTool ?
