- Thank you received: 4
- Forum
- Discussions
- QuickOPC-Classic in .NET
- Browsing, Browse Dialogs and Controls
- OpcLabs.EasyOpc.UA.Engine.UAEngineException - OPC UA service result - {Bad}
08 Jul 2021 17:41 #9964
by micham
Our customer is having a problem when trying to browse the KepServerEX via OPC UA connectivity. See the log below. Can you please explain this error and what may cause this error?
Exceptions
Type: OpcLabs.EasyOpc.UA.Engine.UAEngineException
OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80000000) in 'ApplicationInstance.CheckApplicationInstanceCertificate'. OPC UA service result - {Bad}
+ The error occurred while creating or checking the (client) application instance certificate. Check event log entries for errors and warnings.
+ The certificate generator path was "C:\Program Files (x86)\Control-See\EBO-OPC Client\BIN\Opc.Ua.CertificateGenerator.exe".
+ This is an engine-level error.
+ The client method called (or event/callback invoked) was 'BrowseMultiple'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {Bad} ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {Bad}
--- Koniec śladu stosu wyjątków wewnętrznych ---
Activity Trace:
Following (18) events were gathered during the action on activity ID [19], in the order of first occurrence:
SDK trace: Checking application instance certificate.
SDK trace: Creating application instance certificate. KeySize=0, Lifetime=600
SDK trace: Deleting application instance certificate.
SDK trace: CreateCertificateViaProxy("C:\Program Files (x86)\Control-See\EBO-OPC Client\BIN\Opc.Ua.CertificateGenerator.exe", "C:\ProgramData\OPC Foundation\CertificateStores\MachineDefault", "", "urn:DESKTOP-UQS96VB:EBOOPCClientCFG:1.0.78.0:neutral:null", "EBO-OPC Client Configuration", "", {"DESKTOP-UQS96VB"}, 0, "01/01/0001 00:00:00", 600, 256, False, False, "", "")
SDK trace: filePath: C:\Program Files (x86)\Control-See\EBO-OPC Client\BIN\Opc.Ua.CertificateGenerator.exe
SDK trace: storePath: C:\ProgramData\OPC Foundation\CertificateStores\MachineDefault
SDK trace: applicationUri: urn:DESKTOP-UQS96VB:EBOOPCClientCFG:1.0.78.0:neutral:null
SDK trace: applicationName: EBO-OPC Client Configuration
2*SDK trace: subjectName: CN=EBO-OPC Client Configuration/DC=DESKTOP-UQS96VB
SDK trace: domainNames: DESKTOP-UQS96VB
SDK trace: keySize: 2048
SDK trace: lifetimeInMonths: 600
SDK trace: tempFile: C:\Users\Użytkownik\AppData\Local\Temp\tmp12EE.tmp
SDK trace: result: -cmd issue
Exception: {Opc.Ua.ServiceResultException} Input file was not processed properly.
SDK trace: e: Opc.Ua.ServiceResultException: Input file was not processed properly. w Opc.Ua.CertificateFactory.CreateCertificateViaProxy(String executablePath, String storePath, String password, String applicationUri, String applicationName, String subjectName, IList`1 domainNames, UInt16 keySize, DateTime startTime, UInt16 lifetimeInMonths, UInt16 hashSizeInBits, Boolean isCA, Boolean usePEMFormat, String issuerKeyFilePath, String issuerKeyFilePassword)
Exception: {Opc.Ua.ServiceResultException} Could not create a certificate via a proxy: Input file was not processed properly.
ErrorId: OpcLabs.UAEngine=1
((19, 1), Opc.Ua.TraceEventArgs)
((19, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
c3c0e69e-bf8f-4bfa-8e93-816783737e55: 19
Error Code: 1
Data: ErrorId: Opc.UA.ServiceResult=0x80000000
Help Link:
InnerException: OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {Bad}
Help Link:
Internal Code: 2147483648
Message: OPC UA service result - {Bad}
Service Result: Bad
Additional Info:
Description:
Inner Result:
Qualified Symbolic ID:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Namespace URI String:
Standard Name:
Status Code: Bad
Code Bits: 32768
Code Bits Symbol: Bad
Condition: 0
Flag Bits: 0
Has Data Value Info: False
Info Type: NotUsed
Internal Value: 2147483648
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Semantics Changed: False
Severity: BadOrFailure
Status Info: Error
Structure Changed: False
Text: {Bad}
Service Target Site: System.Security.Cryptography.X509Certificates.X509Certificate2 CreateCertificateViaProxy(System.String, System.String, System.String, System.String, System.String, System.String, System.Collections.Generic.IList`1[System.String], UInt16, System.DateTime, UInt16, UInt16, Boolean, Boolean, System.String, System.String)
DeclaringType: Opc.Ua.CertificateFactory
Module: Opc.Ua.Core.dll
Assembly: Opc.Ua.Core, Version=1.3.342.0, Culture=neutral, PublicKeyToken=6faddca41dacb409
CustomAttributes:
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: cc819e15-c1f0-4cd1-a4cc-c7b59fd7b4d5
ScopeName: Opc.Ua.Core.dll
Source: Opc.Ua.Core
Stack Trace: w Opc.Ua.CertificateFactory.CreateCertificateViaProxy(String executablePath, String storePath, String password, String applicationUri, String applicationName, String subjectName, IList`1 domainNames, UInt16 keySize, DateTime startTime, UInt16 lifetimeInMonths, UInt16 hashSizeInBits, Boolean isCA, Boolean usePEMFormat, String issuerKeyFilePath, String issuerKeyFilePassword)
TargetSite:
Service Result: Bad
Additional Info:
Description:
Inner Result:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Status Code: Bad
Code Bits: 32768
Condition: 0
Flag Bits: 0
Info Type: NotUsed
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Text: {Bad}
CustomAttributes:
MetadataToken: 1
Source: Opc.Ua.Core
Stack Trace:
w Opc.Ua.CertificateFactory.CreateCertificate(String storeType, String storePath, String password, String applicationUri, String applicationName, String subjectName, IList`1 domainNames, UInt16 keySize, DateTime startTime, UInt16 lifetimeInMonths, UInt16 hashSizeInBits, Boolean isCA, Boolean usePEMFormat, String issuerKeyFilePath, String issuerKeyFilePassword, UInt16 algorithm)
w Opc.Ua.CertificateFactory.CreateCertificate(String storeType, String storePath, String applicationUri, String applicationName, String subjectName, IList`1 domainNames, UInt16 keySize, UInt16 lifetimeInMonths)
w Opc.Ua.Configuration.ApplicationInstance.CreateApplicationInstanceCertificate(ApplicationConfiguration configuration, UInt16 keySize, UInt16 lifetimeInMonths)
w Opc.Ua.Configuration.ApplicationInstance.CheckApplicationInstanceCertificate(Boolean silent, UInt16 minimumKeySize)
w OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientEngineBase.<>c__DisplayClass30_0.<ValidateOrCreateClientCertificate>b__2()
w OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.PerformSdkAction(UASdkCallType callType, Func`1 usingFunction, String name, Action sdkAction)
TargetSite:
Message:
Source:
Stack Trace:
== Activity Trace ==
TargetSite:
Source:
TargetSite:
Exceptions
Activity Trace:
Error Code: 1
Help Link:
Help Link:
Service Result: Bad
Additional Info:
Description:
Inner Result:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Status Code: Bad
Code Bits: 32768
Condition: 0
Flag Bits: 0
Info Type: NotUsed
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Text: {Bad}
CustomAttributes:
MetadataToken: 1
Source: Opc.Ua.Core
TargetSite:
Service Result: Bad
Additional Info:
Description:
Inner Result:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Status Code: Bad
Code Bits: 32768
Condition: 0
Flag Bits: 0
Info Type: NotUsed
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Text: {Bad}
CustomAttributes:
MetadataToken: 1
Source: Opc.Ua.Core
Stack Trace:
TargetSite:
Message:
Source:
Stack Trace:
TargetSite:
Source:
TargetSite:
- Forum
- Discussions
