Rockwell RSLInx OPC sever
26 Jan 2021 13:45 #9361 by support
Replied by support on topic Rockwell RSLInx OPC sever
this forum is for users of the QuickOPC product. From your post, it looks like that you are not using QuickOPC. In this case please look for help elsewhere.
26 Jan 2021 11:32 #9357 by Saita
I am browsing with RsiOPCAuto.OPCBrowser from rockwell the RSLinx opc server. I am doing that recursively and everything is working well a part from some kind of arrays declared and istantiated within the PLC.
So if the array is for example an array of integr or real or predefined data types the leaf is returned with the correct name.
If the array is an array of structure the algorithm does not return all the fields of the structure. Example if I have a tag like this
array[10] type is mystructure (with some fields inside) the leaf is not returned as array[0] (or array[1] ... ecc...) but the "Item" is [0], [1] with no name and within that node I cannot find all the fields of the structure
Hope my english can be well understood
