Browsing the DeltaV OPC server fails - "Object is not connected to server"
09 Dec 2020 12:24 #9242 by support
You need to contact the vendor of the product you are using. The likely outcome is that he would instruct you to use a newer version.
09 Dec 2020 12:06 #9241 by nick.chen@thermofisher.com
Yes, I am also connecting to DeltaV OPC server (OPC.DeltaV.1 same CLSID as the one in this thread)
I am not sure of what QuickOPC version right now but I assume it is the same as the one in this thread (QuickOPC.Net version 2018.2) since the product used is micham's product.
09 Dec 2020 12:00 #9240 by support
Are you also connecting to Delta V OPC server?
Which QuickOPC version are you using?
09 Dec 2020 11:57 #9239 by nick.chen@thermofisher.com
I am encountering the same issue as this thread. Was there a solution or resolution in fixing the issue? Is there a procedure in implementing the experimental code?
20 Mar 2020 11:01 #8313 by support
Added experimental code that directs the OPC DA node browsing to the NET API implementation (and not the standard "raw" implementation) when OPC DeltaV server is detected.
Built demo app with the experimental code. According to the customer it works OK (node browsing).
Will make a new QuickOPC 2020.1 build with this change (and also some tracing added in the meantime) - will be in builds 125.1 or later.
20 Mar 2020 10:57 #8312 by support
Memo: Remote session to customer's site performed on 202003190600.
64-bit machine.
Demonstrated problem with EasyOpcNetDemo app built with 5.41.1253.1. Shows "Class not registered" when attempting to browse nodes of OPC.DeltaV.1, runs in 64-bit process though (Michael's app runs in 32 bits). Used CORFLAGS with -32BIT+ /FORCE to switch EasyOpcNetDemo to 32-bit mode. After that, it gives "Object is not connected to server" in the same situation.
Tested with SOClient (is 32 bit). Works OK. Has no OPC DA 3.0 interfaces. Obtained OPC Analyzer trace of that.
Tested 32-bit EasyOpcNetDemo with OPC Analyzer. Unfortunately, it works OK. Obtained OPC Analyzer trace of that.
Server info from server browsing in the demo app:
Technology: OPC-COM
Implements: (OpcDataAccess10, OpcDataAccess20)
Vendor: Fisher-Rosemount Systems Inc.
ProgID: OPC.DeltaV.1
Version-independent ProgID: OPC.DeltaV.1
CLSID: {c3b72ab1-6b33-11d0-9007-0020afb6cf9f}
URL: opcda:OPC.DeltaV.1/%7Bc3b72ab1-6b33-11d0-9007-0020afb6cf9f%7D
Aside from browsing, when ItemID is entered as a string, reads work OK, subscriptions work OK.
Used REGEDIT to explore the registration. 64-bit registry has the ProgID part but not the CLSID part. 32-bit registry has the CLSID part but not the ProgID part. Target executable is FrsOpcDv.exe. Attempted to fix the 64-bit usage by copying the CLSID part to 64-bit registry, but that gave no change in behavior.
No suspicious entries in Windows event logs. The server process appears to be running the whole time (before and after the problem occurrence - no crash).
Later, the customer installed QuickOPC 2020.1 (build 114.1) and retested with its demo app. Same behavior as with 5.41.1253.1.
File Name: upload.zip
File Size:4 KB
17 Mar 2020 07:42 - 20 Mar 2020 10:58 #8309 by micham
Hi Zbynek,
Can you connect now? The customer in China is waiting for us to connect.
Please use new password [removed]
Last edit: 20 Mar 2020 10:58 by support. Reason: removed id/password
16 Mar 2020 15:45 #8307 by support
16 Mar 2020 06:56 #8304 by micham
Thank you. Can you please let me know the date and time of the remote session?
Michael Meirovitz
13 Mar 2020 04:11 - 13 Mar 2020 04:11 #8300 by support
Here is an outline of possible outcomes as I see them, also regarding the notes in email about version "2017" used in your software. It should be made clear that there is no way any change will be made to that old version.
0) We may not find a solution.
1) We will find a solution that works with version "2017" and does not involve any change into our software. Fine then.
2) We will find that the problem does not occur with our current version (2020.x). This is unlikely because there were not significant changes in that area. But if it happens, we will give you a license to the new version, free of charge.
3) We will make a change in our software to resolve the problem. In such case the change will be made to the new version, and we will give you a license to the new version, free of charge.
Last edit: 13 Mar 2020 04:11 by support.
Time to create page: 0.080 seconds
